Re: '71 Dart & min-tubs how much tire will fit?
[Re: 6bblgt]
#2740731
02/07/20 05:34 PM
02/07/20 05:34 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
You can get about 15" of tire width from the frame rail to the fender, if you roll the lip and push the quarter out a little but the real issue is the wheel opening. Without stretching that no way you will get that to fit.
[Re: Guitar Jones]
#2740778
02/07/20 08:34 PM
02/07/20 08:34 PM
Posts: 20,836 A collage of whims
topside
A collage of whims
Sure, all it takes is money ! Definitely will have to stretch the wheel opening length. Not sure if that rear axle is too wide, looks that way. More info would be handy, unless you're just kidding. 13x31s ride under my Duster using its original rear rails. Worst case, new rails further inboard, tubs and some under-car cussing...
[Re: hemienvy]
#2741083
02/08/20 09:52 PM
02/08/20 09:52 PM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
they are U.S. Mags (reproduction U.S. Indy Aluminum Slot Mags) from Summit 15x5 front w/2.5" backspace 15x5 US INDY15x10 rear w/3.5" backspace 15x10 US INDYI think the rear axle housing ended up 50-3/4" flange-to-flange
[Re: 6bblgt]
#2741324
02/09/20 06:39 PM
02/09/20 06:39 PM
Posts: 5,334 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
How much did you end up "stretching" the rear wheel wells?
Plymouth Makes It!
[Re: RoadRunnerLuva]
#2741446
02/10/20 12:06 AM
02/10/20 12:06 AM
6bblgt
Las Vegas, NV
How much did you end up "stretching" the rear wheel wells? a chassis shop moved the inner rear wheel well in flush with the frame rail, where the Caltracs were/are mounted - the outer wheel well is "radiused" to remove the "hump" just above the wheel lip AFAIK the rear wheel lip is the stock profile with stock wheel lip mouldings, the lips are hammered & trimmed - I will confirm how wide the added material is in the wheel well
