Re: 10 sec 440 or 400
[Re: 440727]
#2739593
02/04/20 11:10 AM
02/04/20 11:10 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
Simpler to just stick w/ a 440.
[Re: 440727]
#2739598
02/04/20 11:27 AM
02/04/20 11:27 AM
Thumperdart
State of confusion
My 470 is quicker and faster than a lot of those 500+ strokers and a beast on the street w/good old home ported rpm heads and a .680-.660 solid roll in the mid 9's plus fully street-able.....Fit's better in most engine bays as well....
[Re: 440727]
#2739603
02/04/20 11:43 AM
02/04/20 11:43 AM
BradH
More info needed, such as... - Auto or stick - If auto, converter size & stall - Gearing & tire size - What parts you are starting with - What parts you expect to keep - What parts you're willing to replace - Minimum fuel octane requirement and/or expected CR - Track-only or street/strip - Header size and exhaust requirements - Hydraulic, solid flat-tappet, hyd roller or solid roller cam - Car + driver weight - What does the car run now, and with what current combination - Approx. altitude of local track(s) - REALISTIC BUDGET
[Re: an8sec70cuda]
#2739630
02/04/20 01:01 PM
02/04/20 01:01 PM
Posts: 3,842 N.E. Ohio
6bblFLASH
N.E. Ohio
Simpler to just stick w/ a 440. ABSOLUTELY. Need more info also. Street only ? StreetStrip? Bracket car? I am in the 9.70"s with a .030 440 with average heads .590 MP solid 6bbl. on 93 gas.But it's only 3,000lbs. Strokers are an attractive nuisance LOL. If starting with nothing stroker is just as cheap. Budget build...decent piston and rods STOCK crank and go...
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#2739635
02/04/20 01:14 PM
02/04/20 01:14 PM
fast68plymouth
So. Burlington, Vt.
For a “race car” of reasonable weight, 10’s are a piece of cake.
Every consolation made for the sake of “streetability” will usually cost you some ET.
Thats where the bigger cube strokers start to make more sense.
[Re: 6bblFLASH]
#2739644
02/04/20 01:33 PM
02/04/20 01:33 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Unless you already have the 440, The only things that strike me as easier with the 440 is sourcing the crank and intake choice. After that, almost every advantage goes to the B version. If you’re going to start from scratch with either, intake selection would seem to be the only advantage to the 440, and that’s really only an issue if you’re working with Maxie port sizes. The 400 version is going to weigh less, it’s going to fit easier, it’s going to be marginally stronger in the bottom end, rotating assembly is lighter & bore size is going to be a little bigger so it should rev faster and make a little more power. Less weight up front makes it easier to transfer weight. I vote for the B version. But I am admittedly a little bias since I run one. My car was an original 383 car, so I wanted to keep the orig look. Truth is you can build a really great 10-second B Body with either.
[Re: 440727]
#2739708
02/04/20 05:01 PM
02/04/20 05:01 PM
Posts: 43,289 Bend,OR USA
Cab_Burge
The big advantage of using a good sonic tested 400 block is that you don't have to worry about cracking the main webbing like you do with a stock 440 block I've seen 3 RB blocks with crack main webbing and read about a bunch more of them from guys on here Think twice, build once I've built a bunch of 400 block stroker motors, if your shooting for north of 650 HP on pump gas invest in a good set of main caps, I like and use the aluminum ones with ARP main studs from 440 Source now
[Re: 440727]
#2739889
02/05/20 10:41 AM
02/05/20 10:41 AM
BradH
More info needed, such as... - Auto 727 - turbo action 2200 ?.... sorry been years since built on converter size & stall - Gearing 3.91.... tire size 28 - What parts you are starting with..... have std bore 440 and 400 blocks - What parts you expect to keep... rods - What parts you're willing to replace.... everything - Minimum fuel octane requirement 93 or higher and/or expected CR 10:1 plus - street/strip - Header size and exhaust requirements - Hydraulic, solid flat-tappet, hyd roller or solid roller cam... whatever I need for the setup - Car 3400 + 250 driver weight - What does the car run now, and with what current combination 13.80 95mph - Approx. altitude of local track(s) 1500ft - REALISTIC BUDGET 7500k
' Do you have a stock forged 440 3.75"-stroke crank? And, I'll a$$ume you meant $7,500, not $7,500,000, for your budget. Unless there's a lot more "behind the scenes" that's not covered above, you've got more than just an engine to build to make your goal. EDIT: Off the top of my head while sitting in a long boring meeting that I don't really need to be in... Machine work for acceptable core block: $750+ Stock-stroke OEM crank-based build (regrind good stock core, new rods, new budget forged pistons, new rings & bearings, balanced): $1800+ Budget aluminum standard-port heads prepped & "Stage 1" ported w/ hardware for solid flat-tappet cam: $1500 Good single-plane intake: $300+/- Solid flat-tappet cam & lifters: $400+/- Budget rocker arms & custom pushrods: $700 Budget "race" carburetor: $600+/- 2" headers and basic exhaust system: $1000+/- Torque converter $700+/- Trans rebuild & upgrade for street/strip use (includes valve body): $1500+ My s.w.a.g. estimate is $9250 IF you have some of this stuff already, or can get some of the items above for less $, adjust accordingly IF you need to buy a new budget crank, regardless of 3.75" or stroker, add another $600 to price IF you can't do the entire engine assembly work yourself, add another $1000 for shop to build
[Re: rebel]
#2739941
02/05/20 12:49 PM
02/05/20 12:49 PM
Thumperdart
State of confusion
Try a 1050+ cfm Dommy and get back with us.....
[Re: BradH]
#2739945
02/05/20 12:58 PM
02/05/20 12:58 PM
Posts: 4,700 Wichita
GY3
Wichita
' Do you have a stock forged 440 3.75"-stroke crank? And, I'll a$$ume you meant $7,500, not $7,500,000, for your budget. Unless there's a lot more "behind the scenes" that's not covered above, you've got more than just an engine to build to make your goal. EDIT: Off the top of my head while sitting in a long boring meeting that I don't really need to be in... Machine work for acceptable core block: $750+ Stock-stroke OEM crank-based build (regrind good stock core, new rods, new budget forged pistons, new rings & bearings, balanced): $1800+ Budget aluminum standard-port heads prepped & "Stage 1" ported w/ hardware for solid flat-tappet cam: $1500 Good single-plane intake: $300+/- Solid flat-tappet cam & lifters: $400+/- Budget rocker arms & custom pushrods: $700 Budget "race" carburetor: $600+/- 2" headers and basic exhaust system: $1000+/- Torque converter $700+/- Trans rebuild & upgrade for street/strip use (includes valve body): $1500+ My s.w.a.g. estimate is $9250 IF you have some of this stuff already, or can get some of the items above for less $, adjust accordingly IF you need to buy a new budget crank, regardless of 3.75" or stroker, add another $600 to price IF you can't do the entire engine assembly work yourself, add another $1000 for shop to build Pretty accurate in my experience.
[Re: GY3]
#2739949
02/05/20 01:07 PM
02/05/20 01:07 PM
fast68plymouth
So. Burlington, Vt.
Don’t forget the wheels, tires, shocks, fuel, and ignition systems.
[Re: fast68plymouth]
#2739962
02/05/20 01:25 PM
02/05/20 01:25 PM
GY3
Wichita
Stealths will give you low 11's with a mild street build with "normal" street car weight and all the compromises that come with it.
Spray your way to mid 10's with a 150 shot and have something that you can drive to work every day.
