540 build #2738509
01/31/20 08:43 PM
01/31/20 08:43 PM
usa,pa
jkwedge540 Offline OP
usa,pa
Building a 540short deck. Aluminum block with 4.500 bore. B1 PSO heads. B1 single dominator. My question is can it make 1100 HP? This will be a serious Nitrous motor. Would like to know if a tool steel cam is worth it. Coated piston on so on. Need your thoughts on this. Thanks
Re: 540 build [Re: jkwedge540] #2738559
01/31/20 10:57 PM
01/31/20 10:57 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
When running nitrous, be careful with coated pistons. My experience is with a big block Chevy, but coatings will keep heat from migrating down the rod where engine oil will cool and get rid of the heat. If the heat does not migrate it stays in the chamber where it can melt pistons. Machine shop talked a buddy of mine into coating pistons on a freshen of a proven combination that was taking a lot of nitrous, after the coating, it destroyed itself in just a couple passes. Only change was the coating, in doing some research we rebuilt it with out the coating and it was reliable again. Some said if we would have richened the setup, it would have not had a problem, but we did not have the money to experiment.
Re: 540 build [Re: jkwedge540] #2738561
01/31/20 11:01 PM
01/31/20 11:01 PM
Long Island, NY
B1Johnny Offline
B1Johnny  Offline
Long Island, NY
my pso made 1215 with a Marcella sheet metal excellent heads . the motor is for sale if anyone is interested.
Re: 540 build [Re: jkwedge540] #2739037
02/02/20 02:31 PM
02/02/20 02:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I have a few customers makin that power w/smaller heads but the carb size and tune will make or break the final afr curve and output......would love to mod your carb or build ya a top shelf billet if you're interested...
Re: 540 build [Re: jkwedge540] #2739413
02/03/20 07:52 PM
02/03/20 07:52 PM
I've made 920 HP with a goof up single Dominator carb on a 4.495 bore with a 4.25 stroke crankshaft (13.5 to 1 compression)in a World iron block to be used as a bracket motor with a Koffel prepared B1 originals heads that flowed right at 430 CFM at .800 net lift.
I know other racers out here that have made over 1100 HP with B1 originals with a lot of other good parts shruggy
I have one set of B1 originals with Jesel 1.7 rockers that I'm going to use on a pump gas 572 C.I. KB aluminum wedge block and a set of B1-MC heads with either Jesels or T&D pair shaft rockers on a 555 C.I. Koleno block bracket motor build, I'm hoping for 1100+ HP with two Dominators and a sheet metal tunnel ram on that motor luck
I don't know anything about the B1-PSO heads, sorry blush
Re: 540 build [Re: Cab_Burge] #2739763
02/04/20 08:50 PM
02/04/20 08:50 PM
usa,pa
usa,pa
Has any one used a tool steel cam. Just wondering if it’s worth the money or spend it some where else. Thanks for all the replies.
Re: 540 build [Re: jkwedge540] #2739778
02/04/20 09:17 PM
02/04/20 09:17 PM
I don't think you can buy a cast steel solid roller cam from any of the decent cam company now, they will all be steel billet cores twocents
some will be black coated and some will be copper coated colors between the lobes, both will work well up
Re: 540 build [Re: Cab_Burge] #2739796
02/04/20 10:04 PM
02/04/20 10:04 PM
Deland, Florida
biff426 Offline
biff426  Offline
Deland, Florida
IMHO it is well worth the cost to upgrade to a 55mm cam core the stock cam core will limit you when you start turning the RPM you are going to need to turn to make 1100HP.
