Building a 540short deck. Aluminum block with 4.500 bore. B1 PSO heads. B1 single dominator. My question is can it make 1100 HP? This will be a serious Nitrous motor. Would like to know if a tool steel cam is worth it. Coated piston on so on. Need your thoughts on this. Thanks
