Under hood wire harness replacement #2738306
01/31/20 02:18 AM
01/31/20 02:18 AM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
Anybody who has done this, what is the approximate time to do one? I've got a '66 Barracuda here with a new harness that I will be replacing. I've got an idea of the hours that I think it should take, BUT I'd like to see what anybody else has to say. I'll also be working on the bulkhead, but I know how long that will take me.
Re: Under hood wire harness replacement [Re: Jim_Lusk] #2738330
01/31/20 09:33 AM
01/31/20 09:33 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Jim, Something like 20 years ago I replaced the engine harness on my '67. I was fairly clueless and it still went pretty fast - maybe 1/2 a day - like 4 or 5 hours at most.
Almost every year and body is a little different, but everything for the engine harness is pretty accessible. It will prob include the headlight circuit - on 67 that means removing the front grills. I assume 66 will be the same. - you know these cars well - it should go well.
ps. save the original harness. I've raided mine for reference and parts in time since the replacement. Not every detail on the YO/MH harness is 100% correct so its good to have the original - it will roll up into a box pretty small.
Re: Under hood wire harness replacement [Re: Mattax] #2738337
01/31/20 10:09 AM
01/31/20 10:09 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Are you talking engine harness or headlights too?
I bought an engine harness from Bill and Rose Evans for my '63 330 here recently and it took less than 30 minutes to plug in and be running. All the components were already in place.
'63 Dodge 330
11.19 @ 121 mph
Re: Under hood wire harness replacement [Re: GY3] #2738386
01/31/20 12:21 PM
01/31/20 12:21 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
engine harness ,Im thinking maybe 3 hours or so.
forward lamp harness will be a little more having to route it in behind the grill and stuff. so add maybe an extra hour for that. so maybe 4
If everything underhood. I would plan maybe 5 or 6 tops
extra if you have an issue like I did. had no spark to the coil and had to back trace it back to the bulkhead wire crimp . the wire wasn't stripped bare and the crimp was on the wire insulation
Re: Under hood wire harness replacement [Re: Jim_Lusk] #2738397
01/31/20 12:51 PM
01/31/20 12:51 PM
AndyF Offline
AndyF  Offline
I replaced the front wiring harness in my Duster. It didn't take me any time since I had the car apart. I just plugged the harness into the bulkhead and then when I put the fenders and grill back in I hooked up the lights. If you have to pull the old harness out and replace it with the car all together then it might take a couple of hours if you stay focused on the job.
Re: Under hood wire harness replacement [Re: Jim_Lusk] #2738457
01/31/20 04:50 PM
01/31/20 04:50 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
are you MAKING the harnesses and the replace ? or just installing harnesses already made ?
just replacing the old one with new ones made... damn! maybe 30 minutes!!!! 45 minutes max? I still don't get how some ppl has posted more than an hour ?
now, making them by yourself and replacing after that... Being the picky I am, maybe 2 days long LOL
Re: Under hood wire harness replacement [Re: NachoRT74] #2738462
01/31/20 05:04 PM
01/31/20 05:04 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Now if we get a sixpack... maybe an hour and a half or two hours
not this:
but this:
LOL
Re: Under hood wire harness replacement [Re: Jim_Lusk] #2738540
01/31/20 10:21 PM
01/31/20 10:21 PM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Using a ready made replacement that is true to the 66 Barracuda, MAYBE 1 hour. But maybe 1.5 if the old one is wrapped around Air Conditioner plumbing.
You can get new Bulkhead connectores off Ebay too so if the female side is bad just replace it.
15 Male and 15 Female connectors for $10.99 and free shipping.
Mopar Bulkhead connectors
For my son's 74 D200 I made a total new one with some power relays and wire gauge upgrades and it took me two days. But I added 2 relays for the headlights, 1 horn relay, 2 fan controller relays and a Fog light relay.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Under hood wire harness replacement [Re: Dave_J] #2738555
01/31/20 10:46 PM
01/31/20 10:46 PM
Phoenix, AZ
Jjs72D Offline
Deep in the closet
Jjs72D  Offline
Deep in the closet
Phoenix, AZ
That was nice of you, Dave. I may look into getting some of those to redo the wiring in my 72 Duster.
Re: Under hood wire harness replacement [Re: NachoRT74] #2738580
02/01/20 12:11 AM
02/01/20 12:11 AM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
That's a little short when you consider that the headlights need to come out. I will be working on the bulkhead, but not replacing it unless I find a spare around here that is in good shape. The car has issues, but I already figured one of them out (damn Bouchillon AC/alternator bracket is powder coated...alt is no longer grounded...). I was losing too much voltage to the coil and the Chinese electronic distributor won't fire on 8 volts...
I was figuring about 4 hours total for the harness replacement and bulkhead work.
Re: Under hood wire harness replacement [Re: Jim_Lusk] #2740235
02/06/20 09:30 AM
02/06/20 09:30 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Still removing headlights I think 45 minutes max and making it with calm.
Now I didn't considered the bulkhead job which on an A Body could take maybe couple of hours since is not comfortable. Depending on how deep is the job. Replacing terminals? Just replacing the bulkhead housing? Terminals usually can be simply cleaned. Just degrease it ( any solvent and brush ), sink it in vinegar with a bit of salt to remove rusty and sulfates on terminals ( that greenish stuff sometimes appears ) for a couple of hours, then on baking soda to beat the rest of acids of vinegar. This full process could take 3 to 4 hours if cleaning. If replacing terminals maybe just 2 hours depending on your tools and skills.
I would preffer keep the original terminals. The factory crimping is way better than any crimp job made at home still with the right tools.
Re: Under hood wire harness replacement [Re: NachoRT74] #2740443
02/06/20 05:44 PM
02/06/20 05:44 PM
Fresno, CA
Jim_Lusk Offline OP
Jim_Lusk  Offline OP
Fresno, CA
More like about two hours plus a half hour for checking the bulkhead, which was in good shape.
