Trans brake experience solicited
#2736555
01/25/20 04:32 PM
01/25/20 04:32 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
As I look towards next steps with my car, I’m considering a trans-brake but I’m not really sure if it is in line with what I’m trying to do. So I’m looking for experienced input on one simple question: Are you more consistent with a trans-brake than you are on the footbrake?
Re: Trans brake experience solicited
[Re: J_BODY]
#2736635
01/25/20 08:37 PM
01/25/20 08:37 PM
Posts: 2,516 PA
moparacer
PA
Have done both for years and never really noticed a difference in parts breakage between the two. I run fairly loose converter and a glide so maybe that softens the hit some. I video my passes in car and you can't tell much of a difference between me footbraking at 2600-2800 and trans braking at 3500. Car slows up about .02 footbraking at a lower RPM but that's about it.
As far as consistency, you can be just as good at footbraking as you can with a trans brake, BUT the trans brake can remove a few variables that will make you more consistent IF you are not real good at footbraking.
Especially if you use a delay box.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#2736651
01/25/20 09:20 PM
01/25/20 09:20 PM
Posts: 1,030 ohio
67mprfan
ohio
I also had both and the thing I liked about the trans brake was it made my car more consistent smash the button car is at the same rpm also with the brake I think it helps because my experience with it was suspension is in a neutral position while staging vs footbraking. Now getting used to cutting a good light is definitely a learning curve without using a delay box
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: 67mprfan]
#2736688
01/26/20 12:24 AM
01/26/20 12:24 AM
Posts: 11,637 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
More consistent? Like many things, depends. You really have to optimize the combination for what you are doing. Converter set up, carb, brakes, suspension, etc..
Driver consistency is more of a factor. Can you consistently footbrake the car the same every time or will you benefit from just needing to get your thumb off the button with the RPM being the same every time.
[Re: CMcAllister]
#2736696
01/26/20 02:10 AM
01/26/20 02:10 AM
StealthWedge67
Puyallup, WA
I’m feel pretty confident footbraking, but I’m always looking to improve. I already use a 2-step, so controlling the RPM’s isn’t an issue. I’m mostly just wondering if it’s easier to be consistent with the smaller muscles in your hand than the bigger muscles of your leg. I don’t really care about performance, as I already know a Tbrake won’t typically improve performance much. Like my OP asked, just wondering if you’ve found it easier to be consistent with a button than a pedal.
[Re: StealthWedge67]
#2736715
01/26/20 09:55 AM
01/26/20 09:55 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Like my OP asked, just wondering if you’ve found it easier to be consistent with a button than a peddle. Yes.
[Re: CMcAllister]
#2736848
01/26/20 05:58 PM
01/26/20 05:58 PM
Posts: 1,030 ohio
67mprfan
ohio
X2 on the yes
If you do go with a brake 1 thing to consider is that the A & A brake I used you have to hold the button to use reverse so I had 2 buttons mounted because it was tricky backing up while button was on the steering wheel just FYI
[Re: 67mprfan]
#2737764
01/29/20 03:14 PM
01/29/20 03:14 PM
Posts: 16,928 NC
440Jim
NC
If you do go with a brake 1 thing to consider is that the A & A brake I used you have to hold the button to use reverse so I had 2 buttons mounted because it was tricky backing up while button was on the steering wheel just FYI My Compuflow PG brake is the same way (their external solenoid brake). I mounted a toggle switch to the TB circuit to make backing up while turning the steering wheel easier. Don't have to use the button for backing up anymore. If I am just going straight backwards, the steering wheel button gets the job done.
[Re: 440Jim]
#2737794
01/29/20 04:33 PM
01/29/20 04:33 PM
Triple Threat
Renton Washington
Not worth the expense over your current program. Spend that money on entry fees instead.
[Re: Triple Threat]
#2737841
01/29/20 07:52 PM
01/29/20 07:52 PM
Posts: 1,443 central ohio
nss guy
central ohio
Not worth the expense over your current program. Spend that money on entry fees instead. Exactly what he said, you can be just as good off the footbrake vs the button. You have a good routine going now.
[Re: Triple Threat]
#2737954
01/30/20 01:45 AM
01/30/20 01:45 AM
StealthWedge67
Puyallup, WA
Not worth the expense over your current program. Spend that money on entry fees instead. I like this, and I think I’ll take this advice. Thanks for the responses.
[Re: OUTLAWSSAA]
#2738160
01/30/20 05:16 PM
01/30/20 05:16 PM
Posts: 4,693 Wichita
GY3
Wichita
I don't think the op said if he's running a full tree or a pro tree. If your running a pro tree,you'll need that trans brake. Man, is that ever the truth! I tried footbraking a 6.50 index class at an event with a .400 Pro tree and failed miserably!
