Trans brake experience solicited #2736555
01/25/20 04:32 PM
01/25/20 04:32 PM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
As I look towards next steps with my car, I’m considering a trans-brake but I’m not really sure if it is in line with what I’m trying to do. So I’m looking for experienced input on one simple question:
Are you more consistent with a trans-brake than you are on the footbrake?
Re: Trans brake experience solicited [Re: StealthWedge67] #2736605
01/25/20 07:04 PM
01/25/20 07:04 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Trans brake can be hard on stuff. That was the end of our 8.75 in both cars due to axles twisting. Rather than upgrade axles and spools we stepped up to Dana’s. Converters were also upgraded to prevent ballooning. Overlooked this on the Mirada and it wiped out the thrust surface on the crank. Both of our cars were ladder bar so that was a go... might be trickier on leafs. I feel the tbrake is more consistent.
Re: Trans brake experience solicited [Re: J_BODY] #2736631
01/25/20 08:30 PM
01/25/20 08:30 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have run my car off the foot brake and trans brake. As far as consistency, I saw no difference.
If I am not doing well hitting the tree a brake won't help.
Re: Trans brake experience solicited [Re: J_BODY] #2736635
01/25/20 08:37 PM
01/25/20 08:37 PM
PA
moparacer Offline
moparacer  Offline
PA
Have done both for years and never really noticed a difference in parts breakage between the two. I run fairly loose converter and a glide so maybe that softens the hit some. I video my passes in car and you can't tell much of a difference between me footbraking at 2600-2800 and trans braking at 3500. Car slows up about .02 footbraking at a lower RPM but that's about it.
As far as consistency, you can be just as good at footbraking as you can with a trans brake, BUT the trans brake can remove a few variables that will make you more consistent IF you are not real good at footbraking.
Especially if you use a delay box.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Trans brake experience solicited [Re: moparacer] #2736651
01/25/20 09:20 PM
01/25/20 09:20 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
I also had both and the thing I liked about the trans brake was it made my car more consistent smash the button car is at the same rpm also with the brake I think it helps because my experience with it was suspension is in a neutral position while staging vs footbraking.
Now getting used to cutting a good light is definitely a learning curve without using a delay box
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: Trans brake experience solicited [Re: 67mprfan] #2736688
01/26/20 12:24 AM
01/26/20 12:24 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
More consistent? Like many things, depends. You really have to optimize the combination for what you are doing. Converter set up, carb, brakes, suspension, etc..
Driver consistency is more of a factor. Can you consistently footbrake the car the same every time or will you benefit from just needing to get your thumb off the button with the RPM being the same every time.
Re: Trans brake experience solicited [Re: CMcAllister] #2736696
01/26/20 02:10 AM
01/26/20 02:10 AM
Puyallup, WA
Puyallup, WA
I’m feel pretty confident footbraking, but I’m always looking to improve. I already use a 2-step, so controlling the RPM’s isn’t an issue. I’m mostly just wondering if it’s easier to be consistent with the smaller muscles in your hand than the bigger muscles of your leg. I don’t really care about performance, as I already know a Tbrake won’t typically improve performance much. Like my OP asked, just wondering if you’ve found it easier to be consistent with a button than a pedal.
popcorn
Re: Trans brake experience solicited [Re: StealthWedge67] #2736715
01/26/20 09:55 AM
01/26/20 09:55 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Originally Posted by StealthWedge67
Like my OP asked, just wondering if you’ve found it easier to be consistent with a button than a peddle.
popcorn
Yes.
Re: Trans brake experience solicited [Re: CMcAllister] #2736848
01/26/20 05:58 PM
01/26/20 05:58 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
X2 on the yes
If you do go with a brake 1 thing to consider is that the A & A brake I used you have to hold the button to use reverse so I had 2 buttons mounted because it was tricky backing up while button was on the steering wheel just FYI
Re: Trans brake experience solicited [Re: 67mprfan] #2737764
01/29/20 03:14 PM
01/29/20 03:14 PM
NC
440Jim Offline
440Jim  Offline
NC
My Compuflow PG brake is the same way (their external solenoid brake). I mounted a toggle switch to the TB circuit to make backing up while turning the steering wheel easier. Don't have to use the button for backing up anymore. If I am just going straight backwards, the steering wheel button gets the job done.
Re: Trans brake experience solicited [Re: 440Jim] #2737794
01/29/20 04:33 PM
01/29/20 04:33 PM
Renton Washington
Triple Threat Offline
Renton Washington
Not worth the expense over your current program. Spend that money on entry fees instead.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Trans brake experience solicited [Re: Triple Threat] #2737841
01/29/20 07:52 PM
01/29/20 07:52 PM
central ohio
N
nss guy Offline
nss guy  Offline
N
central ohio
Exactly what he said, you can be just as good off the footbrake vs the button. You have a good routine going now.
Re: Trans brake experience solicited [Re: nss guy] #2737851
01/29/20 08:18 PM
01/29/20 08:18 PM
Southern California
BIG DRAG Offline
BIG DRAG  Offline
Southern California
Are you leaving off a button hooked to your 2 step with the footbrake? I did pretty good with that setup before going to the trans brake.
Re: Trans brake experience solicited [Re: Triple Threat] #2737954
01/30/20 01:45 AM
01/30/20 01:45 AM
Puyallup, WA
Puyallup, WA
I like this, and I think I’ll take this advice. Thanks for the responses.
Re: Trans brake experience solicited [Re: StealthWedge67] #2738138
01/30/20 04:18 PM
01/30/20 04:18 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
I don't think the op said if he's running a full tree or a pro tree. If your running a pro tree,you'll need that trans brake.
Re: Trans brake experience solicited [Re: OUTLAWSSAA] #2738160
01/30/20 05:16 PM
01/30/20 05:16 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Man, is that ever the truth!
I tried footbraking a 6.50 index class at an event with a .400 Pro tree and failed miserably! sleep
'63 Dodge 330
11.19 @ 121 mph
