Re: SS springs, Drag Radials and 600+ HP/600 lb/ft?
[Re: cudadoug]
#2737485
01/28/20 06:24 PM
01/28/20 06:24 PM
Posts: 2,856 Pattison Texas
CSK
Pattison Texas
383man [ Ron] does very well , I'm sure he will speak up.
[Re: CSK]
#2737494
01/28/20 06:53 PM
01/28/20 06:53 PM
Posts: 4,672 Wichita
GY3
Wichita
I was running the 456/457 Superstocks and 275 ET Street Pro's.
Hooked pretty well with SS's but the Cal-Tracs are more consistent.
I have run 11.20's with both at 121-ish mph. Best 60 ft.'s were in the 1.54 range n/a.
The latest Made in Mexico SS springs will NOT last. They bend into a lovely S shape after a couple of seasons and lose arch.
[Re: CSK]
#2737508
01/28/20 07:34 PM
01/28/20 07:34 PM
Posts: 2,042 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I don't use radials (MT 29.5./11.5), but I do use SS springs only. NO Caltracts, NO pinion snubber, no anything. I did add an extra main leaf to the right side spring. .030 over, stock stroke 440, very close to 600 hp, 727, Turbo Action "J" converter, Dana 4:56 gear, car w/ driver 3288 lbs. Foot brake (not no box), 60' 1.38 -1.40, ET 10.30's- 10.40's, 126 mph. Not too bad.
Brian
[Re: cudadoug]
#2737587
01/29/20 01:44 AM
01/29/20 01:44 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
383man [ Ron] does very well , I'm sure he will speak up. How could I have forgotten Ron??!! Of course ! ! ! Thanks guys. Yes I run the 3400 lb SS springs I bought from Mancini. I use the longer ext shocks from MP and there is no adjustment on them. All other suspension is stock other then the Comp 3 way front shocks. Its not killer but I guess its ok for a street car on the Hoosier 30 x 9 radial slicks. I use a Dynamic 9.5 converter and its best is 10.76 @ 125 with a 1.50 best 60. On normal days it runs 10.80's @ 124 with the 60 between 1.50 to 1.53 Myself I love the radial slicks since I run radials up front and I drive on the street all the time on them. The car handles great with radials on all 4 corners as I will never go back to bias tires. Ron
[Re: 383man]
#2737631
01/29/20 09:58 AM
01/29/20 09:58 AM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Ran 28 by 10 Hoosier quick time pro’s with 002/003 s/s springs on my old 70 Duster Ran 9.80’s at 3350 with 1.34 60 foot. Would hook anywhere Just CE 3 way shocks all around
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: jlatessa]
#2737779
01/29/20 03:45 PM
01/29/20 03:45 PM
Posts: 8,249 fredericksburg,va
cudaman1969
fredericksburg,va
Very common in stock class, most all say if a stick go caltrac, autos s/s springs. D-E-F can run in the 10s easy and hook with the wheels in the air. PS. Springs can be bent back rather easily, done many. I can bend one in a circle.
[Re: jlatessa]
#2737791
01/29/20 04:25 PM
01/29/20 04:25 PM
BradH
So good SS springs are not available new anywhere?
Thanks, Joe I don't know if Tri-City Competition still makes their custom Launcher leaf springs that a lot of Stocker guys have used. "A long time ago" the father ran one shop (in Michigan?) and the son ran another in SoCal. One specialized in the suspension part of the business and the other did engine work, IIRC. EDIT: Old thread might have some info, if you're interested: https://board.moparts.org/ubbthread...-tri-city-leaf-springs-still-around.html
[Re: BradH]
#2737812
01/29/20 05:32 PM
01/29/20 05:32 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
My Brother has SS springs from about 3 years ago, with the stock shocks it still went 1.45 60ft, then switched to Strange shocks and its more consistent, runs 11.00s on M/T drag radials, drives it to the track runs 2 classes and drives it home.
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: 65signet]
#2738164
01/30/20 05:42 PM
01/30/20 05:42 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
There's better stuff out there such as Caltracs but with me being on a budget on my old Duster I took Monty Smith's advice and added one leaf to the bone stock leaf springs I had, which strengthened the front segment of the springs. I used Rancho 5way shocks and a 275/60/15 drag radial. I was able to drive the car to the track with 3.23 highway gears, run 10.60's-10.70's and drive it home. It never spun the tires.
[Re: ProSport]
#2738228
01/30/20 08:49 PM
01/30/20 08:49 PM
Posts: 5,160 Texas
dannysbee
Texas
Wonder how the SS or modified stock springs would work with a good set of DA shocks?
Getting old just means you were smarter than some and luckier than others.
