Rare OEM Small Block Front Sump Pan #2736993
01/27/20 09:07 AM
01/27/20 09:07 AM
E
earlymopar Offline OP
E
I'm looking for the OEM front sump oil pan in the attached picture. This one apparently came from a late 60's D100 2WD (small block) pickup but looking at that era, this pan still seems to be a rarely seen style. Have any of you seen a pan like this on other Dodge-Plymouth models?
- EM
Re: Rare OEM Small Block Front Sump Pan [Re: earlymopar] #2737003
01/27/20 10:09 AM
01/27/20 10:09 AM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
What are you needing it to fit?
STOP POTATO HATE!
Re: Rare OEM Small Block Front Sump Pan [Re: earlymopar] #2737022
01/27/20 11:28 AM
01/27/20 11:28 AM
E
E
The dimensions for the pan in the picture are;
Length of Sump = 6 & 1/2" (from the front of the pan to the back of the sump)
Depth of sump = 9 & 1/4"
Pan height above rail behind the sump = 5-1/2"
Non-stock application. Only this pan or something close in an aftermarket pan will work. This is the only "true" front sump OEM pan I've seen. Most that are categorized as front sump are actually more like a mid-sump.
- EM
Re: Rare OEM Small Block Front Sump Pan [Re: earlymopar] #2737081
01/27/20 02:17 PM
01/27/20 02:17 PM
montana
BANDIT Offline
BANDIT  Offline
montana
I believe they were on 68 to 71 W series 318 pickups. I think I have a couple at farm. I’ll look next time I’m out there. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: Rare OEM Small Block Front Sump Pan [Re: BANDIT] #2737101
01/27/20 03:10 PM
01/27/20 03:10 PM
E
E
Thanks much Jim. That information is (by-far) the most specific I've heard. The pan I have is riddled with rust pits so if either of your pans are good, I'm interested if you're wanting to sell. Let me know when you might be able to confirm.
- EM
Re: Rare OEM Small Block Front Sump Pan [Re: Mr PotatoHead] #2737185
01/27/20 06:27 PM
01/27/20 06:27 PM
E
E
Switching to PM....
Re: Rare OEM Small Block Front Sump Pan [Re: earlymopar] #2737227
01/27/20 08:17 PM
01/27/20 08:17 PM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
Who whacked my pics, guy said he was looking for the pan??? What gives.
STOP POTATO HATE!
Re: Rare OEM Small Block Front Sump Pan [Re: earlymopar] #2737255
01/27/20 09:22 PM
01/27/20 09:22 PM
That looks like a early SB V8 van oil pan to me work scope
Re: Rare OEM Small Block Front Sump Pan [Re: Cab_Burge] #2737415
01/28/20 01:04 PM
01/28/20 01:04 PM
E
E
Yes as I mentioned in my post it is a 60's era (late 60's) small block pan but not at all a common model given where the sump is located completely at the front. It (almost) looks like a rear sump turned around at first but in reality there are a lot of differences. Further dialog with other members seems to show this as pan used on late 60's "W" series Sweptline pickups.
