The dimensions for the pan in the picture are;
Length of Sump = 6 & 1/2" (from the front of the pan to the back of the sump)
Depth of sump = 9 & 1/4"
Pan height above rail behind the sump = 5-1/2"
Non-stock application. Only this pan or something close in an aftermarket pan will work. This is the only "true" front sump OEM pan I've seen. Most that are categorized as front sump are actually more like a mid-sump.
- EM
