Cam and crank sensors. #2734498
01/19/20 02:33 PM
01/19/20 02:33 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Is there any difference in late model sensors and early model ones?
No I'm not asking for physical dimensions. I'm asking for volts and signal input.
I know the LS has ones with 12 volts and ones with 5 or 6 volts.
Matt
Re: Cam and crank sensors. [Re: MattW] #2735347
01/21/20 05:34 PM
01/21/20 05:34 PM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
Great question, maybe ask Mopar_Rich? He seems to be an EFI master...
Re: Cam and crank sensors. [Re: moparmitch] #2735377
01/21/20 07:00 PM
01/21/20 07:00 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Mopar changed the sensors several times. I wish they would just stop doing that. i always ask to see the color of the o-ring on the sensor. that tells you what you need. I'll update the post later with what the colors mean. I'm on the road tuning today.
Re: Cam and crank sensors. [Re: Mopar_Rich] #2735916
01/23/20 08:06 PM
01/23/20 08:06 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
popcorn
Re: Cam and crank sensors. [Re: MattW] #2735938
01/23/20 09:36 PM
01/23/20 09:36 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
The 58X sensors have green o-rings
Re: Cam and crank sensors. [Re: Mopar_Rich] #2736044
01/24/20 10:16 AM
01/24/20 10:16 AM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
Is it possible to use a 58X sensor on a 32X wheel?
Lets say i want to use my Hemi 6 on a eagle engine with a carb?
I know i would need to change the relutor wheel first.
Matt
Re: Cam and crank sensors. [Re: MattW] #2736321
01/24/20 10:23 PM
01/24/20 10:23 PM
Delaware
biff426 Offline
biff426  Offline
Delaware
I have both sets of sensors and I believe the eagle and the 6.4 use the same sensors. I have the old sensors in my 6.4 to use a FAST XIM in stand alone mode. I have not run it yet but the old sensors and new sensors are the same size physically. I have not run the old sensors on a 58 tooth wheel but I'm getting ready to see if it works real soon.
Re: Cam and crank sensors. [Re: biff426] #2739780
02/04/20 09:19 PM
02/04/20 09:19 PM
Delaware
biff426 Offline
biff426  Offline
Delaware
Well old sensors and 58 tooth wheel doesn't work. I have the 2009-2012 sensor coming which is suppose to work with the FAST XIM and 58 tooth ring problem is the connector is different.
Re: Cam and crank sensors. [Re: biff426] #2740950
02/08/20 01:59 PM
02/08/20 01:59 PM
Ontario Canada
MattW Offline OP
MattW  Offline OP
Ontario Canada
So it won't work because the different connectors.
Cut new, put on old??
Re: Cam and crank sensors. [Re: MattW] #2741031
02/08/20 06:43 PM
02/08/20 06:43 PM
Delaware
biff426 Offline
biff426  Offline
Delaware
So I bought a pigtail for the 2009-2013 sensor and a 2009-2013 sensor. I spliced it in and the XIM saw the crank signal and fired up. Old sensor and new wheel will not work. And you need the sensor with the green Oring not the red oring with the 58 tooth wheel.
40 Plymouth truck on 89 Dakota,How hard to do?
by RUMBLON. 05/28/20 05:23 PM
Correct direction of torsion bars
by blewbyu. 05/28/20 05:20 PM
How to Download Free Music
by 70sixpkRT. 05/28/20 04:23 PM
1965 Polara
by Neil. 05/28/20 03:53 PM
Moparts Recent Posts
TH400 to RB in 69 b body info
by Clanton. 05/28/20 05:33 PM
Fuel bypass regulator... before or after
by duspan. 05/28/20 05:32 PM
Street Outlaws no prep update
by BobR. 05/28/20 05:27 PM
Random MOPAR DRAG RACE pic of the Day
by 11secdart. 05/28/20 05:25 PM
