E Body Cuda Hood Release Lever Spring #2735809
01/23/20 11:55 AM
01/23/20 11:55 AM
MN
Droop69 Offline OP
Droop69  Offline OP
MN
I am currently working with Stephan (ACR2000) on restoring a couple of Cuda hood release levers 71-74. My springs are broken on both of my levers, and was wondering if anyone has a source for replacement springs?
Has anyone found a vendor that carries the release spring? I am not sure if the Challenger and the Cuda used the same spring.
Thanks!
Re: E Body Cuda Hood Release Lever Spring [Re: Droop69] #2735819
01/23/20 12:23 PM
01/23/20 12:23 PM
MN
Droop69 Offline OP
Droop69  Offline OP
MN
A better pic of the spring by itself. It is the lower right one.
Re: E Body Cuda Hood Release Lever Spring [Re: Droop69] #2736318
01/24/20 10:12 PM
01/24/20 10:12 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
I'm in the same dilemma. Son's cuda has the same problem. Did a little looking but didn't see anything yet. Please let me know if you find something par12730@sbcglobal.net . I will keep looking and if I find someone I will let you know
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: E Body Cuda Hood Release Lever Spring [Re: hulmule] #2736819
01/26/20 03:53 PM
01/26/20 03:53 PM
MN
Droop69 Offline OP
Droop69  Offline OP
MN
Yes, we are striking out so far. I might have to find several releases to make one that will work!
