What do you bolt to for pulling out a gen III
#2735464
01/22/20 12:03 AM
01/22/20 12:03 AM
Posts: 2,255 IL
furious70
IL
and can it handle the weight of the trans being attached? I took the intake off and used the 2 bolt holes under there to put the engine on the stand to change oil pans and such, but are those 2 holes strong enough to use to stab the engine and a 727 into a car? I found some kind of bracket that bolts to those 2 bolts plus something in the front and back, is that the right deal (would work on short block)? https://www.reillymotorsports.com/3rd-gen-hemi-lift-bracket.htmlor these (only works on long block? https://www.powergridinc.com/hemi/
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: What do you bolt to for pulling out a gen III
[Re: furious70]
#2735513
01/22/20 09:20 AM
01/22/20 09:20 AM
Posts: 10,132 A Red State
SNK-EYZ
A Red State
Here's what I made up to pull the 5.7 out of a 2004 Durango 4wd.
The engine is set so far back under the cowl on the Durango's that it has to be really short the tab on the top of it literally goes into the engine hoist/cherry picker. The metric bolts are about 5/16th diameter so I wanted at least 4 holding it to the engine. I made it up on a core engine that I had on an engine.
When I swapped the V-10 in my 99 Ram 4 5/16th bolts in the intake to support it.
In the Ram assembly plant they used 2 of the bellhousing bolts to support the engine/trans/transfer case as it moved down the line in the engine building and put everything on it until it was eventually dropped into the frame. At least a quarter mile of hanging by the two bolts.
[Re: A39Coronet]
#2735662
01/22/20 06:46 PM
01/22/20 06:46 PM
Posts: 2,255 IL
furious70
IL
I used just those 2 bolts in parallel to jack it up to put it on a stand (was on a pallet up until that point so didn't have to worry). I like the idea of that little fixture to get to a 3rd. I agree, the intake bolts look so spindly and into AL I was really uncomfortable using them.
[Re: furious70]
#2735808
01/23/20 11:49 AM
01/23/20 11:49 AM
Posts: 421 montana
BANDIT
montana
I made 2 end pieces for my adjustable picker, the one with a threadable slide, 2 bolts in valley and 2 bolts up on timing cover. Different year engines take some modification of front mount, bit it’s doable. Used it on an ‘07, ‘09 and a ‘14 so far. The adjustable part is nice for doing it by itself or with tranny on. I’ll see if I can post a picture of it. Jim
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: 540challenger]
#2737278
01/27/20 10:32 PM
01/27/20 10:32 PM
Posts: 1,111 Usa
A39Coronet
Usa
This is what I based my design off of, for 1/10th the price. I just used a screw balancer attached to my bracket and then to that upper cover mount. You can sorta see it here
[Re: A39Coronet]
#2737367
01/28/20 10:34 AM
01/28/20 10:34 AM
Posts: 421 montana
BANDIT
montana
Not a good picture, but you get the idea.
