What do you bolt to for pulling out a gen III #2735464
01/22/20 12:03 AM
01/22/20 12:03 AM
IL
furious70 Offline OP
IL
and can it handle the weight of the trans being attached? I took the intake off and used the 2 bolt holes under there to put the engine on the stand to change oil pans and such, but are those 2 holes strong enough to use to stab the engine and a 727 into a car?
I found some kind of bracket that bolts to those 2 bolts plus something in the front and back, is that the right deal (would work on short block)?
https://www.reillymotorsports.com/3rd-gen-hemi-lift-bracket.html
or these (only works on long block?
https://www.powergridinc.com/hemi/
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: What do you bolt to for pulling out a gen III [Re: furious70] #2735513
01/22/20 09:20 AM
01/22/20 09:20 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
Here's what I made up to pull the 5.7 out of a 2004 Durango 4wd.
The engine is set so far back under the cowl on the Durango's that it has to be really short the tab on the top of it literally goes into the engine hoist/cherry picker.
The metric bolts are about 5/16th diameter so I wanted at least 4 holding it to the engine.
I made it up on a core engine that I had on an engine.
When I swapped the V-10 in my 99 Ram 4 5/16th bolts in the intake to support it.
In the Ram assembly plant they used 2 of the bellhousing bolts to support the engine/trans/transfer case as it moved down the line in the engine building and put everything on it until it was eventually dropped into the frame. At least a quarter mile of hanging by the two bolts.
Re: What do you bolt to for pulling out a gen III [Re: furious70] #2735657
01/22/20 06:11 PM
01/22/20 06:11 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I normally don't like to pull on intake bolts, even less on these heads vs standard big block intake carb bolts. Everyone does it, myself included, but that's a lot of weight on those aluminum threads.
I made an angle iron attachment that bolts to the valley holes. It's into steel and the holes accept a larger bolt. I think this is how the factory fixture attached, but there's more than one way to skin a cat.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: What do you bolt to for pulling out a gen III [Re: A39Coronet] #2735662
01/22/20 06:46 PM
01/22/20 06:46 PM
IL
IL
I used just those 2 bolts in parallel to jack it up to put it on a stand (was on a pallet up until that point so didn't have to worry). I like the idea of that little fixture to get to a 3rd. I agree, the intake bolts look so spindly and into AL I was really uncomfortable using them.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: What do you bolt to for pulling out a gen III [Re: furious70] #2735808
01/23/20 11:49 AM
01/23/20 11:49 AM
montana
BANDIT Offline
BANDIT  Offline
montana
I made 2 end pieces for my adjustable picker, the one with a threadable slide, 2 bolts in valley and 2 bolts up on timing cover. Different year engines take some modification of front mount, bit it’s doable. Used it on an ‘07, ‘09 and a ‘14 so far. The adjustable part is nice for doing it by itself or with tranny on. I’ll see if I can post a picture of it. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
Re: What do you bolt to for pulling out a gen III [Re: BANDIT] #2736493
01/25/20 01:37 PM
01/25/20 01:37 PM
NY usa
540challenger Offline
NY usa
Re: What do you bolt to for pulling out a gen III [Re: 540challenger] #2737278
01/27/20 10:32 PM
01/27/20 10:32 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
This is what I based my design off of, for 1/10th the price. I just used a screw balancer attached to my bracket and then to that upper cover mount. You can sorta see it here
Re: What do you bolt to for pulling out a gen III [Re: A39Coronet] #2737367
01/28/20 10:34 AM
01/28/20 10:34 AM
montana
BANDIT Offline
BANDIT  Offline
montana
Not a good picture, but you get the idea.
4600 DA
