Re: engine out the bottom
[Re: bonefish]
#2734777
01/20/20 09:14 AM
01/20/20 09:14 AM
Posts: 20,633 in a cattle trailer down by th...
Guitar Jones
That would depend on how you take it apart. I would measure the ride height so you can reset it and leave the upper control arms in the car. That way you don't disturb any adjustments. It's not a bad idea to have it checked afterwards though.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: topside]
#2734959
01/20/20 03:53 PM
01/20/20 03:53 PM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Resetting the ride height exact to where it was before is a big key to not loosing your current front end alignment when going out the bottom.
I'd count the turns on the torsion bar bolts if I ever have to do it to any of mine...
Typically I disconnect the lower ball joint and tie up the loaded spindles and control arms into the wheel well out of the way.
...FAFO...
[Re: DaytonaTurbo]
#2735514
01/22/20 09:21 AM
01/22/20 09:21 AM
Posts: 19,366 north of coder
moparx
i do all of my alignments, and have for many years, because even for only $70.00, finding shops that either can't or won't dial in the specs you want, plus REALLY understand vintage vehicles, the MANY trips back and forth just to get the steering wheel straight is totally unacceptable ! this was, and still is, the situation around here. if it ain't in "the computer", [even if you ask for specs close to any late model sporty car] it CAN'T be done. now that i'm older, it's tougher than it used to be for me to do, but at least i only have myself to blame if i don't like the way my vehicles go down the road.
