engine out the bottom #2734751
01/20/20 05:58 AM
01/20/20 05:58 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
if you remove the engine and trans out the bottom does the front end need to be realigned?
Re: engine out the bottom [Re: bonefish] #2734777
01/20/20 09:14 AM
01/20/20 09:14 AM
Guitar Jones Offline
That would depend on how you take it apart. I would measure the ride height so you can reset it and leave the upper control arms in the car. That way you don't disturb any adjustments. It's not a bad idea to have it checked afterwards though.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: engine out the bottom [Re: Guitar Jones] #2734779
01/20/20 09:20 AM
01/20/20 09:20 AM
MICHIGAN
DynoDave Offline
DynoDave  Offline
MICHIGAN
iagree
DynoDave
Walter P. Chrysler Club - Great Lakes Region
Member # 12304
1970 Plymouth Duster
1972 Dodge Charger Rallye
https://wichargerguy.proboards.com/
1977 Chrysler Cordoba
Re: engine out the bottom [Re: DynoDave] #2734791
01/20/20 09:51 AM
01/20/20 09:51 AM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
Thanks,i think im gunna try it for the first time.Finding anyone around hear that can align these old cars is impossible.If you can think of anymore tips let me know. up
Re: engine out the bottom [Re: bonefish] #2734863
01/20/20 12:29 PM
01/20/20 12:29 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
If the car's undergoing a restoration, I'd do it, or if for some reason I can't remove the hood.
(I did once pull an engine out the top with the hood on, but it's really tight.)
To me, the TBar agony and the need to raise the body up have been the deal-breakers.
Then again, access to engine/trans/K may be what you need.
Seems to me if you leave the upper control arms attached to the aprons, and the strut rods attached to the K, any alignment change would be zero to very minimal.
Re: engine out the bottom [Re: topside] #2734959
01/20/20 03:53 PM
01/20/20 03:53 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Resetting the ride height exact to where it was before is a big key to not loosing your current front end alignment when going out the bottom.
I'd count the turns on the torsion bar bolts if I ever have to do it to any of mine...
Typically I disconnect the lower ball joint and tie up the loaded spindles and control arms into the wheel well out of the way.
...FAFO...
Re: engine out the bottom [Re: DynoDave] #2734988
01/20/20 04:53 PM
01/20/20 04:53 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
iagree
X2
Re: engine out the bottom [Re: 340Cuda] #2735057
01/20/20 08:11 PM
01/20/20 08:11 PM
blewbyu Offline
blewbyu  Offline
How much is an alignment? $70.00? Just do it when your done.
Re: engine out the bottom [Re: bonefish] #2735198
01/21/20 09:47 AM
01/21/20 09:47 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I would. If you're so inclined, the tools to do your own alignments are cheap now.
Re: engine out the bottom [Re: DaytonaTurbo] #2735514
01/22/20 09:21 AM
01/22/20 09:21 AM
moparx Offline
moparx  Offline
i do all of my alignments, and have for many years, because even for only $70.00, finding shops that either can't or won't dial in the specs you want, plus REALLY understand vintage vehicles, the MANY trips back and forth just to get the steering wheel straight is totally unacceptable ! mad
this was, and still is, the situation around here. if it ain't in "the computer", [even if you ask for specs close to any late model sporty car] it CAN'T be done.
now that i'm older, it's tougher than it used to be for me to do, but at least i only have myself to blame if i don't like the way my vehicles go down the road.
beer
