Re: Fender tag
[Re: 70 buzz]
#2733954
01/17/20 04:42 PM
01/17/20 04:42 PM
Posts: 29,650 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
I told him to run cause what else could be misrepresented Natural reaction. If someone had a fake tag made, what else is bogus? The losers that do it open a 'Pandoras Box' into their own activities.
Re: Fender tag
[Re: Alaskan_TA]
#2733957
01/17/20 04:57 PM
01/17/20 04:57 PM
Posts: 3,392 cheshire, ct
davesmopars
cheshire, ct
only original once
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
Re: Fender tag
[Re: topside]
#2733986
01/17/20 07:34 PM
01/17/20 07:34 PM
Posts: 3,069 Michigan
A727Tflite
After re-reading the ops original question and all the replies since I guess it’s best to just not add another question to this post.
Re: Fender tag
[Re: topside]
#2733996
01/17/20 08:38 PM
01/17/20 08:38 PM
Posts: 3,680 South San Francisco, Ca
70sixpkrt
If a car has a repro FT, the original one had better be with the car or its paperwork. I can understand having a repro tag if the original is damaged & unsightly, but to create one to falsify data is wrong. I have my pristine fender on my car and want to make another so I can put that on and not worry about someone stealing my original.
Re: Fender tag
[Re: Alaskan_TA]
#2734088
01/18/20 09:55 AM
01/18/20 09:55 AM
Posts: 10,706 North Dakota
6PakBee
North Dakota
Definitions;
Fake - Any detail guessed at or changed.
So if I have a car with no fender tag, I inventory all the options and equipment it has, and have a fender tag made to reflect that inventory, it is automatically a fake?
Re: Fender tag
[Re: 6PakBee]
#2734094
01/18/20 10:11 AM
01/18/20 10:11 AM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
So if I have a car with no fender tag, I inventory all the options and equipment it has, and have a fender tag made to reflect that inventory, it is automatically a fake? What would you have to guess at it that case? The SPD & the VON for '69 up cars. More guesses yet if it is a Lynch Road tag. Guesses on tags are noticeable & yes, I call them fakes.
Re: Fender tag
[Re: Alaskan_TA]
#2734209
01/18/20 02:08 PM
01/18/20 02:08 PM
Posts: 1,893 michigan
70 buzz
michigan
What year did they start adding the vin to the tag 68?? Even car before they started adding the vin to the tag a person can make the car to reflect the car I would call fake. I see it has an alternative reason to try to make a car to the vin. Buyer beware. I seen fake build sheets also for what purposes, to me it is to deceive someone.
Re: Fender tag
[Re: 70 buzz]
#2734246
01/18/20 04:26 PM
01/18/20 04:26 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
What year did they start adding the vin to the tag 68?? Even car before they started adding the vin to the tag a person can make the car to reflect the car I would call fake. I see it has an alternative reason to try to make a car to the vin. Buyer beware. I seen fake build sheets also for what purposes, to me it is to deceive someone. 1969
Re: Fender tag
[Re: Alaskan_TA]
#2734506
01/19/20 02:58 PM
01/19/20 02:58 PM
6PakBee
North Dakota
So if I have a car with no fender tag, I inventory all the options and equipment it has, and have a fender tag made to reflect that inventory, it is automatically a fake? What would you have to guess at it that case? The SPD & the VON for '69 up cars. More guesses yet if it is a Lynch Road tag. Guesses on tags are noticeable & yes, I call them fakes. Good points.
Re: Fender tag
[Re: RoadRunnerLuva]
#2734525
01/19/20 03:53 PM
01/19/20 03:53 PM
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
What if someone had all the original paperwork for a vehicle...( original broadcast sheet/original sales invoice/original window sticker/original title) and the fender tag was long gone. Let's say the owner wanted to have a tag made, to reflect all the FACTORY CORRECT info from the original paperwork...is that a fake? It depends........ Lynch Road fender tags have gate & series numbers that were not recorded on original paperwork. Windsor used its own codes at times & some of their broadcast sheets have no option data printed from about 1/2 way down. Hamtramck tags with the same SPD have a code on one car of the same model that does not appear on the car one VIN away even when the codes are on the broadcast sheets. If I had a car with all that other documentation but no fender tag I'd leave it that way. I would also consider going to a shop that does engraving to have a 'reward' tag made as mentioned above.
Re: Fender tag
[Re: Alaskan_TA]
#2734530
01/19/20 04:08 PM
01/19/20 04:08 PM
Posts: 9,432 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
Hamtramck tags with the same SPD have a code on one car of the same model that does not appear on the car one VIN away even when the codes are on the broadcast sheets. BW, Can you explain that a bit more? You mean a non option code? Also since ham had two lines would it be safe to say they had two tag machines? I ask that because I have two slightly different fonts on a few certain numbers on two tags, same SPD. id have to look but the vin is 3 off of each other, and it is not a fluke because its not a rare thing, the only thing I can come up with is they had two fonts, and oddly the same odd font deal carries over to the door stickers as well. Ive actually two pairs of cars with the vins less then 8 apart, both pairs just goofy luck bought at different times. I had a new door tag for one made and even ECS wasnt aware of the same day different font deal until I provided proof. What if someone had all the original paperwork for a vehicle...( original broadcast sheet/original sales invoice/original window sticker/original title) and the fender tag was long gone. Let's say the owner wanted to have a tag made, to reflect all the FACTORY CORRECT info from the original paperwork...is that a fake? It depends........ Lynch Road fender tags have gate & series numbers that were not recorded on original paperwork. Windsor used its own codes at times & some of their broadcast sheets have no option data printed from about 1/2 way down. Hamtramck tags with the same SPD have a code on one car of the same model that does not appear on the car one VIN away even when the codes are on the broadcast sheets. If I had a car with all that other documentation but no fender tag I'd leave it that way. I would also consider going to a shop that does engraving to have a 'reward' tag made as mentioned above.
STOP POTATO HATE!
