DANA AXLE BEARINGS AND SEALS #2733887
01/17/20 12:56 PM
01/17/20 12:56 PM
WV
JohnH Offline OP
JohnH  Offline OP
WV
1969 B Body I have a axle seal leaking on a Dane rear end. I'm going to replace both seals and bearing on both sides. NAPA shows different seal and bearing P/N for different gear ratio's.. Do I need to know my ratio, or all the axle seals and bearing for a Dana pretty much the same? Thanks for any info..
Re: DANA AXLE BEARINGS AND SEALS [Re: JohnH] #2733896
01/17/20 01:11 PM
01/17/20 01:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Dana axle bearings and seals are the same as the 8 3/4". Gear ratio is irrelevant.
Re: DANA AXLE BEARINGS AND SEALS [Re: JohnH] #2733897
01/17/20 01:15 PM
01/17/20 01:15 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
It gets confusing with some parts lists, just be sure to only tell them 3.54 or 4.10, those are dana ratios. Dana and 8-3/4, 3.55, 3.91, 4.11 use a different inner seal. I would suggest an E-mail or call to Cass at Doctor diff and get the right stuff the first time.
Re: DANA AXLE BEARINGS AND SEALS [Re: John_Kunkel] #2733900
01/17/20 01:20 PM
01/17/20 01:20 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
Inner seals are not the same bearings and outer seals are. Stock dana passenger car seals are 2.5002 in diameter, 8-3/4 are 2.69 diameter..stock housing.
Re: DANA AXLE BEARINGS AND SEALS [Re: 4406bbl] #2733911
01/17/20 01:54 PM
01/17/20 01:54 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
