LOOKING FOR GOOD QUALITY OIL CAP #2732781
01/13/20 07:00 PM
01/13/20 07:00 PM
Finally a HUSKER again
Moparnut426 Offline OP
Looking for a good quality oil cap for a 70 440 sixpac engine. mine leaks and the rubber sealing part is harder than a wedding night wood.
The parts house caps are always crap, and I hat a bleeding cap and messy Valve Cover.....
Re: LOOKING FOR GOOD QUALITY OIL CAP [Re: Moparnut426] #2732782
01/13/20 07:03 PM
01/13/20 07:03 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
[quote=Moparnut426]Looking for a good quality oil cap for a 70 440 sixpac engine. mine leaks and the rubber sealing part is harder than a wedding night wood.
laugh2
Re: LOOKING FOR GOOD QUALITY OIL CAP [Re: 5carguy] #2732791
01/13/20 07:58 PM
01/13/20 07:58 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Pretty sure you can replace the seal. If you can't find a one new....it would be pretty easy to cut from gasket stock. Otherwise the Stant cap is a pretty good replacement. I have a few if you have trouble finding one.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: LOOKING FOR GOOD QUALITY OIL CAP [Re: 70gtx440dana] #2733047
01/14/20 05:19 PM
01/14/20 05:19 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I tried that - cutting gasket material to fit on mine . . . still seeps . . (small block, but same issue) . . . I have gone through the PCV system and it works great, so it's not like it is pressurized . .
Re: LOOKING FOR GOOD QUALITY OIL CAP [Re: a12rag] #2733078
01/14/20 07:00 PM
01/14/20 07:00 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Assuming the sealing flange in the valve cover is dead flat...
I've replaced the cap seal with a rubber donor from a parts-store gas cap or radiator cap.
ID is the important thing, OD can be trimmed pretty easily.
If the cap fits loosely, and it's not from cap or cover damage, you can double up the seal.
Re: LOOKING FOR GOOD QUALITY OIL CAP [Re: topside] #2733309
01/15/20 11:40 AM
01/15/20 11:40 AM
Its a brand new AMD cover, not super happy with the thin seal area on the VC, but it should seal. Ill double the seal on the new cap ans see what happens In the past I have crimped the steel tabs on the cap to fit tighter, but that didnt help this cap.
