Re: A body front steer rack
[Re: 6bblFLASH]
#2733720
01/16/20 07:37 PM
01/16/20 07:37 PM
Posts: 2,530 PA
moparacer
PA
Lower ball joints are swapped on bothe cars. Doesn't this induce a bunch of positive camber when you do that? I was looking at trying that one time and I remember the ball joint was angled and offset so I automatically ruled that possibility out.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#2733737
01/16/20 08:26 PM
01/16/20 08:26 PM
Posts: 3,842 N.E. Ohio
6bblFLASH
N.E. Ohio
Didn`t effect the camber. That I could see. Did`nt have any issues getting everything to line up. The 68` needs more caster,has power rack and ratio is too quick/light. However it is a lot of work to add caster or remove it. Tie-rod length and height would need to be changed also.......too lazy to do all that again.
At ride height the rack and tie-rods need to be somewhat level. Beyond that you will get severe toe-in at max travel up or down---toe-out in the middle or a combination of both.,which is why a common band-aid is restrict front end travel. On a fast drag car you don`t need much travel which makes it a lot simpler. Street cars or roundy stuff is much much harder to retro-fit. Main reason I made my own K frame.
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas 9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ! 2013 StickShift Challenge Winner@ Mopar Nationals!
[Re: 6bblFLASH]
#2733899
01/17/20 01:18 PM
01/17/20 01:18 PM
Posts: 10,034 Frostbitefalls MN (Rocky&Bullw...
gregsdart
The key is a combination of rack length that fita the length of the lower control arms for zero bumpsteer and also places the tie rod end correctly for ackerman for a street car. For a race car(mine) zero ackerman saved my keester three times and allowed me to correct quickly when i blew an oil system gasket at 150 mph , got sideways at 125 mph on a slick track, and again at 135 mph when i hit a dip in the track with the brakes on hard.. I don't recall seeing many successfully recovering from being out of shape as bad as i was. Credit the fact that the front wheels stayed dead parallel at all steering angles so the front end didn't push me into a spinout.
[Re: NoFrills]
#2734219
01/18/20 03:04 PM
01/18/20 03:04 PM
Posts: 2,530 PA
moparacer
PA
Well I talked myself out of building one. To many other projects going on. This should be done in a few months. Is that a few months wait time for him to build you the suspension? And what does a setup like that cost? I am probably going to go that route too so I can keep the factory spindles and brakes but I need to be going back together pretty quick for the start of the season.
[Re: NoFrills]
#2734229
01/18/20 03:30 PM
01/18/20 03:30 PM
Posts: 422 montana
BANDIT
montana
That is a nice looking set up. Does it use your stock spindle then? Jim
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
[Re: NoFrills]
#2734303
01/18/20 08:37 PM
01/18/20 08:37 PM
Posts: 43,352 Bend,OR USA
Cab_Burge
What brand is it and can you provide us contact info please ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) Are you going to way it and all your old parts also? The reason I'm asking is I had a early A body tube K frame, it weighed 2 lbs. less than the stock K frame did before cleaning the stock one ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif) 21 lbs. for the tube one and 23 lbs. for the stock K member on a 1000 lb. certified warehouse scale ![work work](/ubbthreads/images/graemlins/custom/work.gif) I have several 1967 and later stock A and B body K members so it will be interesting to hear on your weight differences on the B body K members only. I've ben using elephant ears and front motor plates for years on my hot street and strip cars and I know all the engine mount parts add up on weight, my last BB Duster had right at 49.7 % weight on the rear tires, 50.3 % on the front tires ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif) That baby would hook up in a mud puddle in the middle of a rain storm ![devil devil](/ubbthreads/images/graemlins/custom/devil.gif) ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) AKA, aside it flat worked well ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif) I did move the rear axle forward one inch ( I had to stretch the rear wheel wells five inches, three inches on the front side and two inches on the rear side ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif) ) and I moved the 400 block back as far back as I could and still get the valve covers off with the heater installed ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: Cab_Burge]
#2734338
01/18/20 10:45 PM
01/18/20 10:45 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
Even adding a lot of gussits to my son's 68 Dart front X member and I added a lot, it was still about 28 pounds on my bathroom scale....
Now total weight, what is taken off and added back on? The manual box VS Mustang II rack? Stock slot motormounts VS motor plates with Elephant ears?
I can't see the items weighting much different.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: NoFrills]
#2734386
01/19/20 10:25 AM
01/19/20 10:25 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Well I talked myself out of building one. To many other projects going on. This should be done in a few months. I have this set up on my car as well. Been thru dragweek and won my class. With the cost of this set up don’t know why you would do it yourself. For what you see in pictures it is $1550. Tory Shellehamer makes them and you can find him on Facebook .
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: Cab_Burge]
#2734390
01/19/20 10:34 AM
01/19/20 10:34 AM
1967dartgt
Hilltown Pa
What brand is it and can you provide us contact info please ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) Are you going to way it and all your old parts also? The reason I'm asking is I had a early A body tube K frame, it weighed 2 lbs. less than the stock K frame did before cleaning the stock one ![shock shock](/ubbthreads/images/graemlins/custom/shock.gif) 21 lbs. for the tube one and 23 lbs. for the stock K member on a 1000 lb. certified warehouse scale ![work work](/ubbthreads/images/graemlins/custom/work.gif) I have several 1967 and later stock A and B body K members so it will be interesting to hear on your weight differences on the B body K members only. I've ben using elephant ears and front motor plates for years on my hot street and strip cars and I know all the engine mount parts add up on weight, my last BB Duster had right at 49.7 % weight on the rear tires, 50.3 % on the front tires ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif) That baby would hook up in a mud puddle in the middle of a rain storm ![devil devil](/ubbthreads/images/graemlins/custom/devil.gif) ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) AKA, aside it flat worked well ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif) I did move the rear axle forward one inch ( I had to stretch the rear wheel wells five inches, three inches on the front side and two inches on the rear side ![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif) ) and I moved the 400 block back as far back as I could and still get the valve covers off with the heater installed I have weight the parts multiple times and posted them here and Facebook, it’s 65lbs difference. With that much weight on rear tires were you trying for a wheel stander? 😎
[Re: NoFrills]
#2734437
01/19/20 12:26 PM
01/19/20 12:26 PM
Posts: 8,374 fredericksburg,va
cudaman1969
fredericksburg,va
Well I talked myself out of building one. To many other projects going on. This should be done in a few months. Really like the design of the lower control arm connections (triangle), rack is way to far forward but it can be moved. There’s a lot of spindles out there designed with the tie rod in front, just use the the proper ball joints. You don’t have to stay with the Chrysler type either. Speedway makes one for circle track. Just my 2 Cents
[Re: cudaman1969]
#2734445
01/19/20 12:34 PM
01/19/20 12:34 PM
1967dartgt
Hilltown Pa
Well I talked myself out of building one. To many other projects going on. This should be done in a few months. Really like the design of the lower control arm connections (triangle), rack is way to far forward but it can be moved. There’s a lot of spindles out there designed with the tie rod in front, just use the the proper ball joints. You don’t have to stay with the Chrysler type either. Speedway makes one for circle track. Just my 2 Cents Rack is just in front of balancer. Where are you going to move it? Can’t go back farther the engine is there. I guess your gonna mount it under the engine and jack up ride height? Don’t see how your idea is possible.
[Re: 1967dartgt]
#2734491
01/19/20 01:58 PM
01/19/20 01:58 PM
Posts: 2,530 PA
moparacer
PA
Well I talked myself out of building one. To many other projects going on. This should be done in a few months. I have this set up on my car as well. Been thru dragweek and won my class. With the cost of this set up don’t know why you would do it yourself. For what you see in pictures it is $1550. Tory Shellehamer makes them and you can find him on Facebook . Shot him a PM on Facebook. Thanks!
[Re: 1967dartgt]
#2734835
01/20/20 11:32 AM
01/20/20 11:32 AM
cudaman1969
fredericksburg,va
Well I talked myself out of building one. To many other projects going on. This should be done in a few months. Really like the design of the lower control arm connections (triangle), rack is way to far forward but it can be moved. There’s a lot of spindles out there designed with the tie rod in front, just use the the proper ball joints. You don’t have to stay with the Chrysler type either. Speedway makes one for circle track. Just my 2 Cents Rack is just in front of balancer. Where are you going to move it? Can’t go back farther the engine is there. I guess your gonna mount it under the engine and jack up ride height? Don’t see how your idea is possible. If so I would not have it, I want the rack swivel centerline on the inner pivot of the lca and the tie rod tube parallel to the lca because as we know the upper and lower control arms pivot on a different arc. The higher the outside tie rod is the more it will toe outl on a wheely. This puts the rack below the balanced. I’ll add..IMO
[Re: 1967dartgt]
#2734851
01/20/20 12:05 PM
01/20/20 12:05 PM
Posts: 4,701 On the parachute mount
n20mstr
Well I talked myself out of building one. To many other projects going on. This should be done in a few months. I have this set up on my car as well. Been thru dragweek and won my class. With the cost of this set up don’t know why you would do it yourself. For what you see in pictures it is $1550. Tory Shellehamer makes them and you can find him on Facebook . Looks like a great swap from the stock setup. other than tubular uppers and strut bars to carry the weight of the coil holding the front up, what shock is needed? obviously a coil over type and I guess you can use your own length too 65lbs sounds great too !
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#2735260
01/21/20 12:54 PM
01/21/20 12:54 PM
1967dartgt
Hilltown Pa
Well I talked myself out of building one. To many other projects going on. This should be done in a few months. I have this set up on my car as well. Been thru dragweek and won my class. With the cost of this set up don’t know why you would do it yourself. For what you see in pictures it is $1550. Tory Shellehamer makes them and you can find him on Facebook . Looks like a great swap from the stock setup. other than tubular uppers and strut bars to carry the weight of the coil holding the front up, what shock is needed? obviously a coil over type and I guess you can use your own length too 65lbs sounds great too ! I run a Afco da shock with 5 in stroke. I run one designed to fit a factory mopar in stock location. I believe my shock is part number 3850m but can’t remember for sure. If you are really serious I can go n my garage and get it for you.
