2.19 intake valves for Eddy RPM heads #2731640
01/10/20 06:03 AM
01/10/20 06:03 AM
Hamburg / Germany
Den300 Offline OP
Den300  Offline OP
Hamburg / Germany
Hello,
does anybody knows where to get 2.19" intake valves for Edelbrock RPM heads (part nr. 60929)?
11/32" (0.341") steam diameter and 4.908" length. Seems that Hughes Engines are the only ones or I am to blind?
Dan Dvorak seems to be out of business and Manley & Co dont list them in there catalogue. Any other vendors?
And do I Need new seat or can I use the ones that come with the 2.14" valves?
thanks!
Dennis
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: 2.19 intake valves for Eddy RPM heads [Re: Den300] #2731690
01/10/20 11:02 AM
01/10/20 11:02 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
is it worth spending the money to upgrade the edelbrock heads with larger valves? can the port support the larger valve? is money better spent getting a better head? maybe a trickflow240 or 270.. asking the questions because I don't know.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: 2.19 intake valves for Eddy RPM heads [Re: Den300] #2731715
01/10/20 12:05 PM
01/10/20 12:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I had Pettis install 2.19 valves in my rpm's and I'd say an easy 6.15 @ 112 mph on a crappy 1.40 60 ain't so bad and I think they are REV or something like that iirc........
Re: 2.19 intake valves for Eddy RPM heads [Re: Jerry] #2731754
01/10/20 01:41 PM
01/10/20 01:41 PM
Hamburg / Germany
Den300 Offline OP
Den300  Offline OP
Hamburg / Germany
Absolute, but I do run old school domed TRWs and I am afraid this wont match with the much smaller and different shaped combustion chamber.
And changing pistons leads to rebalancing, etc..thats out of scope timing wise, but the TF are for sure great valued heads! Might use them for next year with a 512 Stroker as I got a brand new 337 intake to play with grin
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: 2.19 intake valves for Eddy RPM heads [Re: Den300] #2731768
01/10/20 02:04 PM
01/10/20 02:04 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Originally Posted by Den300
Hello,
thanks!
Dennis
I saw on Facebook yesterday where Dan Dvorak is in the hospital with cancer and not doing well.
'63 Dodge 330
11.19 @ 121 mph
Re: 2.19 intake valves for Eddy RPM heads [Re: GY3] #2731775
01/10/20 02:07 PM
01/10/20 02:07 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
I don't; know if anyone has flowed a set of the rpm heads after cnc porting and with 2.19 valves. I assume your heads still have the stock intake port and not the max wedge ports. I run a set of edelbrock heads from when the first came out and were the only game in town. it would be good to know if you gain anything by going to the larger valves.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: 2.19 intake valves for Eddy RPM heads [Re: Jerry] #2731777
01/10/20 02:10 PM
01/10/20 02:10 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Run down this list:
https://www.ferrea.com/Chrysler-Engine-Valves/p34267
IIRC there is something that should work.
Re: 2.19 intake valves for Eddy RPM heads [Re: GY3] #2732050
01/11/20 05:53 AM
01/11/20 05:53 AM
Hamburg / Germany
Den300 Offline OP
Den300  Offline OP
Hamburg / Germany
thats sad! this f... disease...he was alsways very kind on the phone frown
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: 2.19 intake valves for Eddy RPM heads [Re: Jerry] #2732052
01/11/20 05:57 AM
01/11/20 05:57 AM
Hamburg / Germany
Den300 Offline OP
Den300  Offline OP
Hamburg / Germany
Based on my readings some 10-20+ cfm in the mid range. We dont have a flow bench so no real chance to measure it precise. Heads are already hand ported and roughly 20% larger then stock but not max wedge.
It would shift max hp too high as the car is used 75% on the street. 15 years ago Indy was overkill and RPMs the only real alternative.
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: 2.19 intake valves for Eddy RPM heads [Re: Jeremiah] #2732053
01/11/20 05:58 AM
01/11/20 05:58 AM
Hamburg / Germany
Den300 Offline OP
Den300  Offline OP
Hamburg / Germany
Originally Posted by Jeremiah
Run down this list:
Been there before but they are all a bit too long. Will talk to my engine builder if that still fits with the springs and retainers. But thanks for suggestion up
Hamburg/Germany
69 Chrysler 300
446cui Dual Quad
12.64 @ 110.7
Re: 2.19 intake valves for Eddy RPM heads [Re: Den300] #2732116
01/11/20 12:35 PM
01/11/20 12:35 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
i don't have time to look, but i think i remember there being some 2.19 intake valves for the RPM heads here.
http://www.sivalves.com/
Re: 2.19 intake valves for Eddy RPM heads [Re: krautrock] #2732122
01/11/20 12:45 PM
01/11/20 12:45 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
Yes thy do have them , sure wish I would have seen these when I redid my Stealths 2 years ago. Thank You for the link !!!
Re: 2.19 intake valves for Eddy RPM heads [Re: Den300] #2732126
01/11/20 12:49 PM
01/11/20 12:49 PM
Washington
madscientist Offline
Washington
Run down this list:
So what if they are a bit too long? By how much? .060? .100? If so, you can use a different spring for the longer installed height and get the spring load back where it should be (if it's .060 or so I'd shim the spring you have).
Then, you go to b3racingengines.com and read ALL his tech pages. Then order a geometry correction kit and you are DONE.
If you do that, and you can use a bit longer valve out of a catalog, you'll most likely never get screwed again by not being able to by a valve off the shelf.
