Door panel install? #2731216
01/08/20 07:40 PM
01/08/20 07:40 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Does anyone have a diagram of clip location install on door panels for a 70 RR... ? Orientation etc...
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Door panel install? [Re: JMCFAN] #2731282
01/08/20 10:49 PM
01/08/20 10:49 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Most door panels should have some the hole locations marked in the cardboard.???
Tip if you want it is to use Velcro instead of the clips. Looks the same once it's together and far easier to take apart later.
Re: Door panel install? [Re: Neil] #2731305
01/09/20 01:59 AM
01/09/20 01:59 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Amen to the far easier!!!
Joe
Re: Door panel install? [Re: Neil] #2731407
01/09/20 01:02 PM
01/09/20 01:02 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
The cut outs are there....but not indication on the orientation....Velcro.....hmm..?
Re: Door panel install? [Re: JMCFAN] #2731421
01/09/20 01:41 PM
01/09/20 01:41 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Got a photo of the back of your panel?
Is it an original or aftermarket?
Re: Door panel install? [Re: Alaskan_TA] #2731428
01/09/20 02:05 PM
01/09/20 02:05 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Aftermarket.... Legendary
Re: Door panel install? [Re: JMCFAN] #2731438
01/09/20 02:26 PM
01/09/20 02:26 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Factory had a kind of arrowhead in the cutouts for clip orientation, but I think the barbs ft/rear are at the outermost location.
I don't have an original one to photo, but I would think someone here will.
Otherwise it's going to take some measuring/mock-up.
Bummer they don't punch those out of the backing, since EVERY car used them...
Re: Door panel install? [Re: topside] #2731445
01/09/20 02:36 PM
01/09/20 02:36 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Yea the originals on my Charger are arrow shaped....I may be able to use those to figure out...or trial and error. Was just wondering if there was a diagram somewhere. Legendary should provide for the price of these things....
Re: Door panel install? [Re: JMCFAN] #2731457
01/09/20 02:51 PM
01/09/20 02:51 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Install all of them like the left clip-in other words pointing outward
Re: Door panel install? [Re: Paul Jacobs] #2731458
01/09/20 02:53 PM
01/09/20 02:53 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
Thanks!
Re: Door panel install? [Re: JMCFAN] #2731460
01/09/20 02:54 PM
01/09/20 02:54 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
Added picture to show you’re welcome
Re: Door panel install? [Re: JMCFAN] #2731462
01/09/20 03:00 PM
01/09/20 03:00 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I could see what my original 68 panels have when I get home. But I will throw this out there. You may not want to use those clips. They will imprint on the vinyl on the other side. DAMHIK. The factory used a stamped flat steel one like the picture I attached. Not sure if AMK or or someone has them.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Door panel install? [Re: RoadRunner] #2731486
01/09/20 04:28 PM
01/09/20 04:28 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Yes, those clips can telegraph thru to the vinyl panel.
Re: Door panel install? [Re: Neil] #2731490
01/09/20 04:46 PM
01/09/20 04:46 PM
A collage of whims
A collage of whims
I've seen both types used; the flat ones seem better for showing through.
Main thing is you don't just whack the panels onto the car, take your time & line everything up.
Re: Door panel install? [Re: topside] #2731551
01/09/20 07:43 PM
01/09/20 07:43 PM
New Mexico
JMCFAN Offline OP
JMCFAN  Offline OP
New Mexico
I have the wire ones on my Charger...cant see anything on the panels... what was original... ?
Re: Door panel install? [Re: JMCFAN] #2731559
01/09/20 08:10 PM
01/09/20 08:10 PM
INDIANA
P
Paul Jacobs Offline
Paul Jacobs  Offline
P
INDIANA
They used both styles, but the guys are right, the flat style is really smooth on aftermarket panels. Original material was tougher and thicker on both door panels and seat upholstery and didn't show as much.
I just ordered some NOS seat material dated 1968 and was shocked at how thick it is compared to Legendary stuff.
