Door panel install?
#2731216
01/08/20 07:40 PM
01/08/20 07:40 PM
Posts: 2,090 New Mexico
JMCFAN
New Mexico
Does anyone have a diagram of clip location install on door panels for a 70 RR... ? Orientation etc...
68 Charger 383/ AT Green/Green VT 70 Roadrunner 383/4sp Purple/Black VT
Re: Door panel install?
[Re: Neil]
#2731407
01/09/20 01:02 PM
01/09/20 01:02 PM
JMCFAN
New Mexico
Most door panels should have some the hole locations marked in the cardboard.???
Tip if you want it is to use Velcro instead of the clips. Looks the same once it's together and far easier to take apart later. The cut outs are there....but not indication on the orientation....Velcro.....hmm..?
[Re: Alaskan_TA]
#2731428
01/09/20 02:05 PM
01/09/20 02:05 PM
JMCFAN
New Mexico
Aftermarket.... Legendary
[Re: topside]
#2731445
01/09/20 02:36 PM
01/09/20 02:36 PM
JMCFAN
New Mexico
Yea the originals on my Charger are arrow shaped....I may be able to use those to figure out...or trial and error. Was just wondering if there was a diagram somewhere. Legendary should provide for the price of these things....
[Re: JMCFAN]
#2731457
01/09/20 02:51 PM
01/09/20 02:51 PM
Posts: 1,039 INDIANA
Paul Jacobs
INDIANA
Aftermarket.... Legendary Install all of them like the left clip-in other words pointing outward
[Re: JMCFAN]
#2731462
01/09/20 03:00 PM
01/09/20 03:00 PM
Posts: 5,137 East Aurora (Buffalo) NY
RoadRunner
I could see what my original 68 panels have when I get home. But I will throw this out there. You may not want to use those clips. They will imprint on the vinyl on the other side. DAMHIK. The factory used a stamped flat steel one like the picture I attached. Not sure if AMK or or someone has them.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: topside]
#2731551
01/09/20 07:43 PM
01/09/20 07:43 PM
JMCFAN
New Mexico
I have the wire ones on my Charger...cant see anything on the panels... what was original... ?
