Building a billet motor plate
#2731409
01/09/20 01:11 PM
01/09/20 01:11 PM
Posts: 656 Florida
CJD AUTOMOTIVE
I had always planned to run a motor plate on my car. When I got my Jesel belt drive and saw how much of the belt was exposed, I figured why not make a plate that would also enclose the timing belt. If I was enclosing the belt, this would also give me a place to mount the cam sensor. So I started templating accessory locations. Went through many paper templates trying to figure out what fit where, does it have enough clearance, etc... The layout really came down to what fit where, with enough clearance. I then made some wood templates so I could actually hang the accessories. This took a few tries as well to find out where everyone was happy. With this complete, time to put it in CAD and print a template. This last pic shows the belt cover/water pump back plate. No need to reinvent the wheel here, so I picked a 4" Meziere billet mechanical pump: This pump has a back plate that is removable. We will make a new back plate that intersects the block feed holes, provides mounting to the motor plate, and has auxiliary water feeds for the fittings at the side of my block. Big thanks to Jesel and Meziere for the .DXF files of the timing cover and water pump outline. Saved me a bunch of time and hassle.
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: building a billet motor plate
[Re: CJD AUTOMOTIVE]
#2731416
01/09/20 01:30 PM
01/09/20 01:30 PM
Posts: 656 Florida
CJD AUTOMOTIVE
It was at this point I got my engineer friend involved. He solved some issues on the backplate and really just went over everything again. He is much more proficient at CAD than I am, and as a bonus, is also a machinist. I then moved to measuring all the accessories. Huge PITA. Used a surface plate and height mic, but allowed everything to get transferred into Solid Works: It was coming together, but still not happy with belt wrap, so more tweaks were needed. Ended up adding 4 idlers and a mechanical tensioner to achieve proper belt wrap and length. Also wanted to incorporate the crank sensor bracket. Performed some lightening on the plate and then ran some FEA test. Made a few modifications that affected weight very little but increased strength 35%.
#2731419
01/09/20 01:38 PM
01/09/20 01:38 PM
Posts: 656 Florida
CJD AUTOMOTIVE
#2731471
01/09/20 03:40 PM
01/09/20 03:40 PM
Posts: 4,457 Washington
madscientist
Washington
Very freaking cool.
What is sad is these blocks are so hard to come by. This is the kind of thing that happens when guys start making power and develop cool stuff. You can use it with a production block, but who is going to try and make the kind of power you are with a stock block?
[Re: TRENDZ]
#2731483
01/09/20 04:18 PM
01/09/20 04:18 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
That is incredibly cool, please keep us updated!
68 Barracuda Formula S 340
[Re: Bad340fish]
#2731491
01/09/20 04:48 PM
01/09/20 04:48 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Thanks guys. Yeah, I got a little time in this! Had one issue I solved the best I could, but you guys are smart, so I'll see what your solution would be. The motor plate sits against the timing plate and then through bolted from the the plate to the block. Basically sandwiching the timing cover and using it's 8 bolt holes. I need the timing plate to stay sealed to the block when removing the motor plate, especially important because I'm a dry sump. I also need it located. I put O-ring grooves on both sides of the plate to solve any gasket issue of sticking or leaking. I thought about bolt dowels, but then would have to machine the block. I came up with a pin that is threaded on either end with a small hex to tighten. The pin will have a stud on the block side and female threads on the plate side. The timing cover will have the upper two holes enlarged for the guide pins, locating it, and be able to be tightened down, securing it. This leaves a receiver for the bolt coming through from the motor plate: This will locate and secure the timing cover and motor plate, and the water pump back plate will just have two simple pin dowels. This should also keep the cam and crank sensors in the same positions.
#2731571
01/09/20 08:56 PM
01/09/20 08:56 PM
Superfreak
Superfreak
Excellent work and very cool to boot.
#2731585
01/09/20 09:44 PM
01/09/20 09:44 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Your solution looks very professional and expen$ive. I am assuming you would need to make/ have made, the fasteners. I would think it would be easier to get fully threaded studs with the overall length you need, and use something like an ARP 12pt nut to retain the timing cover to the block. Then, plunge mill the motor plate just deep enough to fit over the small nuts.
[Re: TRENDZ]
#2731589
01/09/20 09:58 PM
01/09/20 09:58 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Your solution looks very professional and expen$ive. I am assuming you would need to make/ have made, the fasteners. I would think it would be easier to get fully threaded studs with the overall length you need, and use something like an ARP 12pt nut to retain the timing cover to the block. Then, plunge mill the motor plate just deep enough to fit over the small nuts. That was my initial idea, but I need to precisely locate the timing cover and motor plate. Using a stud would require bolt dowels in the blocks threaded holes. The setup and machining on the block for this seemed more expensive and difficult than turning a precision threaded pin.
#2731639
01/10/20 05:20 AM
01/10/20 05:20 AM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
Just amazing effort , like making a watch . But more fun .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2731653
01/10/20 09:21 AM
01/10/20 09:21 AM
Posts: 577 Arkansas
Adrielp
Arkansas
Love seeing threads like this. Amazing work!
Adriel Paradise Substation Design Engineer III
[Re: J_BODY]
#2732685
01/13/20 12:24 PM
01/13/20 12:24 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Thanks guys,
It's been a journey, and the engineering cost way more than I was expecting...like I would have never done it if I knew it would have cost that much!!
But that part is paid and over, so on to machining. Shopping it to a few shops now. I'll update when the chips start flying.
[Re: Twostick]
#2732694
01/13/20 12:44 PM
01/13/20 12:44 PM
Posts: 656 Florida
CJD AUTOMOTIVE
I'm not seeing an engine to chassis mount component in the design.
Kevin
? Not sure I know what you mean. The ear on either side with four bolt holes will attach to a bracket on the chassis.
#2732698
01/13/20 12:57 PM
01/13/20 12:57 PM
Posts: 6,562 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
Kevin
? Not sure I know what you mean. The ear on either side with four bolt holes will attach to a bracket on the chassis. Well maybe I'm exceeding my amateur engineering skills here but I was thinking that kind of diagonal mounting might introduce some detrimental dynamics into the chassis. The mounting ears on any motor plate I've ever seen are symmetrical. Kevin
[Re: Twostick]
#2732701
01/13/20 01:15 PM
01/13/20 01:15 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Kevin
? Not sure I know what you mean. The ear on either side with four bolt holes will attach to a bracket on the chassis. Well maybe I'm exceeding my amateur engineering skills here but I was thinking that kind of diagonal mounting might introduce some detrimental dynamics into the chassis. The mounting ears on any motor plate I've ever seen are symmetrical. Kevin Yep, the layout, with the accessories I run, wouldn't allow a symmetrical layout. I wanted it to be, tried multiple layouts, but simply couldn't make it work. There will be a connecting bar above the plate, and the plate will act as a cross brace. This is a road race car, so much more load on the engine bay bars than a straight line car. The plate was FEA tested and loaded at 1000 lbs. ft. from the attaching points and only showed 0.002" deformation. Add in the upper bar and lower sway bar tube, and the contact point isn't that important, it becomes a cross braced box.
#2732785
01/13/20 07:15 PM
01/13/20 07:15 PM
Posts: 22,696 Bitopia
jcc
Bitopia
Its beautiful, but with that investment, I feel like it would be hard to ever in the future change my mind. You might also consider adding a 3/4 axis CNC to your shop. Did you mention the alloy?
