Page 1 of 3 1 2 3
Building a billet motor plate #2731409
01/09/20 01:11 PM
01/09/20 01:11 PM
CJD AUTOMOTIVE Offline OP
I had always planned to run a motor plate on my car. When I got my Jesel belt drive and saw how much of the belt was exposed, I figured why not make a plate that would also enclose the timing belt. If I was enclosing the belt, this would also give me a place to mount the cam sensor. So I started templating accessory locations. Went through many paper templates trying to figure out what fit where, does it have enough clearance, etc...
The layout really came down to what fit where, with enough clearance. I then made some wood templates so I could actually hang the accessories. This took a few tries as well to find out where everyone was happy.
With this complete, time to put it in CAD and print a template.
This last pic shows the belt cover/water pump back plate. No need to reinvent the wheel here, so I picked a 4" Meziere billet mechanical pump:
This pump has a back plate that is removable. We will make a new back plate that intersects the block feed holes, provides mounting to the motor plate, and has auxiliary water feeds for the fittings at the side of my block.
Big thanks to Jesel and Meziere for the .DXF files of the timing cover and water pump outline. Saved me a bunch of time and hassle.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2731411
01/09/20 01:24 PM
01/09/20 01:24 PM
moparx Offline
moparx  Offline
VERY NICE work ! up bow
beer
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2731416
01/09/20 01:30 PM
01/09/20 01:30 PM
It was at this point I got my engineer friend involved. He solved some issues on the backplate and really just went over everything again. He is much more proficient at CAD than I am, and as a bonus, is also a machinist.
I then moved to measuring all the accessories. Huge PITA. Used a surface plate and height mic, but allowed everything to get transferred into Solid Works:
[Linked Image][Linked Image]
It was coming together, but still not happy with belt wrap, so more tweaks were needed. Ended up adding 4 idlers and a mechanical tensioner to achieve proper belt wrap and length.
Also wanted to incorporate the crank sensor bracket.
Performed some lightening on the plate and then ran some FEA test.
[Linked Image]Made a few modifications that affected weight very little but increased strength 35%.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2731419
01/09/20 01:38 PM
01/09/20 01:38 PM
At this point, needed to see if I had a viable piece to machine.
I had the motor plate CNC routered, and the brackets 3D printed.
And bolt it up. Glad I did this extra step, a few small tweaks and it's ready to machine:
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2731471
01/09/20 03:40 PM
01/09/20 03:40 PM
Washington
madscientist Offline
Washington
Very freaking cool.
What is sad is these blocks are so hard to come by. This is the kind of thing that happens when guys start making power and develop
cool stuff. You can use it with a production block, but who is going to try and make the kind of power you are with a stock block?
Re: building a billet motor plate [Re: madscientist] #2731475
01/09/20 03:52 PM
01/09/20 03:52 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
You should put a little more time into planning and building. grin
Re: building a billet motor plate [Re: TRENDZ] #2731483
01/09/20 04:18 PM
01/09/20 04:18 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That is incredibly cool, please keep us updated!
68 Barracuda Formula S 340
Re: building a billet motor plate [Re: Bad340fish] #2731491
01/09/20 04:48 PM
01/09/20 04:48 PM
Thanks guys. Yeah, I got a little time in this!
Had one issue I solved the best I could, but you guys are smart, so I'll see what your solution would be.
The motor plate sits against the timing plate and then through bolted from the the plate to the block. Basically sandwiching the timing cover and using it's 8 bolt holes. I need the timing plate to stay sealed to the block when removing the motor plate, especially important because I'm a dry sump. I also need it located. I put O-ring grooves on both sides of the plate to solve any gasket issue of sticking or leaking. I thought about bolt dowels, but then would have to machine the block. I came up with a pin that is threaded on either end with a small hex to tighten. The pin will have a stud on the block side and female threads on the plate side. The timing cover will have the upper two holes enlarged for the guide pins, locating it, and be able to be tightened down, securing it. This leaves a receiver for the bolt coming through from the motor plate:
This will locate and secure the timing cover and motor plate, and the water pump back plate will just have two simple pin dowels. This should also keep the cam and crank sensors in the same positions.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2731571
01/09/20 08:56 PM
01/09/20 08:56 PM
Superfreak
Superfreak
Excellent work and very cool to boot.
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2731585
01/09/20 09:44 PM
01/09/20 09:44 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Your solution looks very professional and expen$ive. I am assuming you would need to make/ have made, the fasteners. I would think it would be easier to get fully threaded studs with the overall length you need, and use something like an ARP 12pt nut to retain the timing cover to the block. Then, plunge mill the motor plate just deep enough to fit over the small nuts.
Re: building a billet motor plate [Re: TRENDZ] #2731589
01/09/20 09:58 PM
01/09/20 09:58 PM
That was my initial idea, but I need to precisely locate the timing cover and motor plate. Using a stud would require bolt dowels in the blocks threaded holes. The setup and machining on the block for this seemed more expensive and difficult than turning a precision threaded pin.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2731639
01/10/20 05:20 AM
01/10/20 05:20 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Just amazing effort , like making a watch . But more fun .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: building a billet motor plate [Re: tex013] #2731653
01/10/20 09:21 AM
01/10/20 09:21 AM
Arkansas
Adrielp Offline
Adrielp  Offline
Arkansas
Love seeing threads like this. Amazing work!
Adriel Paradise
Substation Design Engineer III
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2732607
01/12/20 11:19 PM
01/12/20 11:19 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Cool stuff Craig! Thanks for sharing the whole process.
Re: building a billet motor plate [Re: J_BODY] #2732685
01/13/20 12:24 PM
01/13/20 12:24 PM
Thanks guys,
It's been a journey, and the engineering cost way more than I was expecting...like I would have never done it if I knew it would have cost that much!!
But that part is paid and over, so on to machining. Shopping it to a few shops now. I'll update when the chips start flying.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2732689
01/13/20 12:37 PM
01/13/20 12:37 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I'm not seeing an engine to chassis mount component in the design.
Kevin
Re: building a billet motor plate [Re: Twostick] #2732694
01/13/20 12:44 PM
01/13/20 12:44 PM
Kevin
? Not sure I know what you mean. The ear on either side with four bolt holes will attach to a bracket on the chassis.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2732698
01/13/20 12:57 PM
01/13/20 12:57 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Kevin
Well maybe I'm exceeding my amateur engineering skills here but I was thinking that kind of diagonal mounting might introduce some detrimental dynamics into the chassis. shruggy The mounting ears on any motor plate I've ever seen are symmetrical.
Kevin
Re: building a billet motor plate [Re: Twostick] #2732701
01/13/20 01:15 PM
01/13/20 01:15 PM
Kevin
Kevin
Yep, the layout, with the accessories I run, wouldn't allow a symmetrical layout. I wanted it to be, tried multiple layouts, but simply couldn't make it work.
There will be a connecting bar above the plate, and the plate will act as a cross brace. This is a road race car, so much more load on the engine bay bars than a straight line car. The plate was FEA tested and loaded at 1000 lbs. ft. from the attaching points and only showed 0.002" deformation. Add in the upper bar and lower sway bar tube, and the contact point isn't that important, it becomes a cross braced box.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: building a billet motor plate [Re: CJD AUTOMOTIVE] #2732785
01/13/20 07:15 PM
01/13/20 07:15 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Its beautiful, but with that investment, I feel like it would be hard to ever in the future change my mind.
You might also consider adding a 3/4 axis CNC to your shop. biggrin
Did you mention the alloy?
Page 1 of 3 1 2 3
