Re: What are you using to warm you up? [Re: DrCharles] #2731082
01/08/20 01:51 PM
01/08/20 01:51 PM
Guitar Jones Offline
Originally Posted by DrCharles
I'd be really nervous about any kind of flame in a garage using gasoline, carb cleaner and other solvents... whistling
In my garage and barn I only have an Ashley Graham poster. She'll keep you warm in the winter all right smile
shock
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: What are you using to warm you up? [Re: Guitar Jones] #2731136
01/08/20 03:54 PM
01/08/20 03:54 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
shock
Exactly. I was always taught never to use open flames and volatile substances in the same area whistling
Re: What are you using to warm you up? [Re: DrCharles] #2731142
01/08/20 04:02 PM
01/08/20 04:02 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Moving for a Stay-cation SOUTH OF 33802 will definitely.....
wArM yOu Up ! up
Re: What are you using to warm you up? [Re: Guitar Jones] #2731145
01/08/20 04:05 PM
01/08/20 04:05 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
shock
sEz the apimp jsta north of 33802 Now moving onto a ski slope !
Re: What are you using to warm you up? [Re: dOrk !] #2731146
01/08/20 04:05 PM
01/08/20 04:05 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Sorry,FL is just too humid for me... it's bad enough in south Missouri!
Re: What are you using to warm you up? [Re: DrCharles] #2731148
01/08/20 04:16 PM
01/08/20 04:16 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
Hay dR .... good ole Misory isn’t AridZona either !
It’s beautiful now ! ... 72 degrees .. 36% !!
Re: What are you using to warm you up? [Re: DrCharles] #2731149
01/08/20 04:16 PM
01/08/20 04:16 PM
Tucson, AZ
Ramrod39 Offline
My New Title
Ramrod39  Offline
My New Title
Tucson, AZ
A post for the Penguins...
Remember the old penguins vs hippos thing here?
Re: What are you using to warm you up? [Re: Greg55_99] #2731150
01/08/20 04:19 PM
01/08/20 04:19 PM
AndyF Offline
AndyF  Offline
Heated floor in my shop so I don't need to worry about open flames or fumes or fans blowing dust around. My last shop was not heated and I froze my fingers this time of year. It was painful to work out there once the temp dropped down into the 40's.
Re: What are you using to warm you up? [Re: DrCharles] #2731152
01/08/20 04:23 PM
01/08/20 04:23 PM
North East USA
BIGGERED Offline
Reasonable Title
BIGGERED  Offline
Reasonable Title
North East USA
shock
I recall my previous homeowners insurance specifically excluding fire if I installed a wood burner in the garage.
Was thinking that was standard boiler plate?
Red
Re: What are you using to warm you up? [Re: BIGGERED] #2731154
01/08/20 04:28 PM
01/08/20 04:28 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Hydronic floor heating in mine. Love it. No regrets.
Rich H.
Esse Quam Videri
Re: What are you using to warm you up? [Re: ZIPPY] #2731168
01/08/20 05:32 PM
01/08/20 05:32 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have a Mitsubishi mini split. Heats in the winter, cools in summer. Very efficient and I don't really notice it on my electric bill.
Re: What are you using to warm you up? [Re: dOrk !] #2731169
01/08/20 05:33 PM
01/08/20 05:33 PM
shock
You would be hitting nothing but trees on the way down. It's pretty thick forrest.
Re: What are you using to warm you up? [Re: Guitar Jones] #2731171
01/08/20 05:45 PM
01/08/20 05:45 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
shock
but BANJOnes .... you’ll be cutting down those trees to heat your house and garage !
Re: What are you using to warm you up? [Re: 340Cuda] #2731210
01/08/20 07:18 PM
01/08/20 07:18 PM
central il.
second 70 Offline
second 70  Offline
central il.
Ditto The outside unit I bought can run up to three separate indoor units. I run a four car garage and a 300sft great room on mine. Each room has their own inside unit. You can see it mounted on the wall over the tool box.
Re: What are you using to warm you up? [Re: dOrk !] #2731211
01/08/20 07:18 PM
01/08/20 07:18 PM
Just the garage, the house has gas heaters and the gas is free!!!!!
Re: What are you using to warm you up? [Re: Guitar Jones] #2731215
01/08/20 07:33 PM
01/08/20 07:33 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
That’s right ... I musta had a Looneyville moment!
...and I’m sure you’ll need ever burp of that gas ! .... will you be able to pipe that in to your ski lodge ?
Re: What are you using to warm you up? [Re: DrCharles] #2731631
01/10/20 01:08 AM
01/10/20 01:08 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Originally Posted by Hemi_Joel
I pre-buy 1000 gallons per year in mid summer when prices are low. I don't have to take delivery of all 1000 gallons at once, they come out on a regular schedule and keep it full. I usually don't use 1000 gallons, so I get credit for what I don't use
Wow... that must be a thousand bucks (or two) just to heat your shop! I used to live in Presque Isle, Maine and in Feb. the heating oil bill was more than the mortgage (small older house).
And worth every penny Doctor C.! This is Minnesota, but I definitely I don't do cold. Pengrim
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
