Re: looking for suggestions Dart tire size
[Re: modelmakerinc]
#2731037
01/08/20 09:54 AM
01/08/20 09:54 AM
Posts: 13,226 Marion, South Carolina [><]
an8sec70cuda
245-60 is as wide as you can go as far as I know. Only offered by BFG, unless someone else has found otherwise? That's what I'm putting on the rear of my '71 Demon w/ its original sbp 14" ralleyes. I think I'm going w/ a 215-70 up front.
235-60 is pretty common.
[Re: an8sec70cuda]
#2731038
01/08/20 09:56 AM
01/08/20 09:56 AM
Posts: 16,032 Mesa, Arizona
dart4forte
Mesa, Arizona
Cooper has a 245/60
Abe Lincoln
[Re: dart4forte]
#2731047
01/08/20 10:26 AM
01/08/20 10:26 AM
Posts: 19,866 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
My first car was a 71 Swinger with 14" slot mags and I had 245/60-14 on the back. If your unsure then go with the 235's.
I can't recall the front tire size. I want to say they were 215 somethings.
[Re: an8sec70cuda]
#2731061
01/08/20 11:00 AM
01/08/20 11:00 AM
Posts: 440 Frederick , MD
GibW340
Frederick , MD
Agree 245 60s Have on my 72 Scamp with rallyes- 7 1/4 stock rear No clearance problems may be room for 255s....
[Re: Mattax]
#2731132
01/08/20 02:38 PM
01/08/20 02:38 PM
Posts: 17,478 Las Vegas, NV
6bblgt
Las Vegas, NV
a friend just put these on his '73 Dart GENERAL ALTIMAX RT43 215/70/14 on 14x5.5" big bolt pattern RALLYE wheels, front 225/70/14 on 14x6.0" big bolt pattern RALLYE wheels, rear the factory small bolt pattern RALLYEs only come in 14x5.5" -  I wouldn't recommend the 245/60/14s on the 5.5' wide wheels & the 14" 60 series tires are just too short
[Re: elmor353]
#2731238
01/08/20 07:26 PM
01/08/20 07:26 PM
Posts: 20,040 So Near, Yet So Far
topside
So Near, Yet So Far
I agree with 6bbl. 60-series 14" tires are short. FWIW, decades ago I had a '73 Dart, Slant/Tflite, that I used to commute, which included some 65-70 mph time. I wound up with 215 & 235/70s on 15x7 steelies, which were a tight fit; rears could rub with backseat passengers. Helped with the RPM/MPH a lot, not so much acceleration, but it was slow even with its stock 14s.
[Re: modelmakerinc]
#2731353
01/09/20 09:03 AM
01/09/20 09:03 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
A typical all season radial, or slightly performance oriented tire in that size will not be expensive. General, BFG, and probably Uniroyal still offer 215/70-14 and such. I'd expect Continental, Michelin, and Goodyear to be a little more expensive but you never know. At least as important is the specific tire model. The more 'performance oriented' street tires almost always cost more. This is true whether its a studless performance snow tire, or ultra performance summer only tire.
When looking, remember the treadwear and traction ratings are based on other tires made by that manufacturer. IMO general higher tread wear rating is generally not any worth trade off for decreased traction. Also depending on how much the car will be used and where it sits, may end up replacing the tires before the tread depth is worn out.
[Re: 76Beeper]
#2731440
01/09/20 01:28 PM
01/09/20 01:28 PM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
All 'A' bodys are not equal My sons 68 Dart 270 has its rear sub frame welded in unevenly. When it had the 155/78 13's you could not tell by looking. But once Tubbed and we put some 275 /45 18's on front and 325/45 20's in the rear the right side tire is too close to the fender. The A body 1965 Barracuda has bigger rear fenderwells. I had 245/70 15's back there and could put my hand all around the wheelwell. When we put my LRT's slotted 15 rims on it with 275/60 15's they fit tight and did not rub unless in a corner or if I had two 200 pound guys in the rear seat. Running SS springs in stock location. Pictures are with the Cop Car Rally's and 275/60 15's
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: an8sec70cuda]
#2732146
01/11/20 12:37 PM
01/11/20 12:37 PM
Posts: 5,824 nowhere
Sniper
nowhere
245-60 is as wide as you can go as far as I know. That was as big as I could fit in the back of my 72 Swinger and only after rolling the fender lip, gave me about 1/2" of clearance there. The inner sidewall would just kiss the leafs in a hard turn, had maybe 3/8" static clearance. Other than the fender lip mod no other mods were done.
