Re: What are you using to warm you up?
[Re: DrCharles]
#2731082
01/08/20 01:51 PM
01/08/20 01:51 PM
Posts: 20,698 in a cattle trailer down by th...
Guitar Jones
I'd be really nervous about any kind of flame in a garage using gasoline, carb cleaner and other solvents... In my garage and barn I only have an Ashley Graham poster. She'll keep you warm in the winter all right
[Re: DrCharles]
#2731148
01/08/20 04:16 PM
01/08/20 04:16 PM
Posts: 30,537 Florida STAYcation
dOc !
The village idiot's idiot
Florida STAYcation
Sorry,FL is just too humid for me... it's bad enough in south Missouri! Hay dR .... good ole Misory isn’t AridZona either ! It’s beautiful now ! ... 72 degrees .. 36% !!
[Re: DrCharles]
#2731152
01/08/20 04:23 PM
01/08/20 04:23 PM
Posts: 1,497 North East USA
BIGGERED
Reasonable Title
Reasonable Title
North East USA
I'd be really nervous about any kind of flame in a garage using gasoline, carb cleaner and other solvents... In my garage and barn I only have an Ashley Graham poster. She'll keep you warm in the winter all right Exactly. I was always taught never to use open flames and volatile substances in the same area I recall my previous homeowners insurance specifically excluding fire if I installed a wood burner in the garage. Was thinking that was standard boiler plate? Red
[Re: BIGGERED]
#2731154
01/08/20 04:28 PM
01/08/20 04:28 PM
Posts: 17,926 S.E. Michigan
ZIPPY
S.E. Michigan
Hydronic floor heating in mine. Love it. No regrets.
Rich H.
Esse Quam Videri
[Re: dOc !]
#2731169
01/08/20 05:33 PM
01/08/20 05:33 PM
Guitar Jones
I'd be really nervous about any kind of flame in a garage using gasoline, carb cleaner and other solvents... In my garage and barn I only have an Ashley Graham poster. She'll keep you warm in the winter all right sEz the jsta north of 33802 Now moving onto a ski slope ! You would be hitting nothing but trees on the way down. It's pretty thick forrest.
[Re: Guitar Jones]
#2731171
01/08/20 05:45 PM
01/08/20 05:45 PM
dOc !
Florida STAYcation
I'd be really nervous about any kind of flame in a garage using gasoline, carb cleaner and other solvents... In my garage and barn I only have an Ashley Graham poster. She'll keep you warm in the winter all right sEz the jsta north of 33802 Now moving onto a ski slope ! You would be hitting nothing but trees on the way down. It's pretty thick forrest. but BANJOnes .... you’ll be cutting down those trees to heat your house and garage !
[Re: 340Cuda]
#2731210
01/08/20 07:18 PM
01/08/20 07:18 PM
Posts: 1,715 central il.
second 70
central il.
I have a Mitsubishi mini split. Heats in the winter, cools in summer. Very efficient and I don't really notice it on my electric bill. Ditto The outside unit I bought can run up to three separate indoor units. I run a four car garage and a 300sft great room on mine. Each room has their own inside unit. You can see it mounted on the wall over the tool box.
[Re: dOc !]
#2731211
01/08/20 07:18 PM
01/08/20 07:18 PM
Guitar Jones
Just the garage, the house has gas heaters and the gas is free!!!!!
[Re: Guitar Jones]
#2731215
01/08/20 07:33 PM
01/08/20 07:33 PM
dOc !
Florida STAYcation
Just the garage, the house has gas heaters and the gas is free!!!!! That’s right ... I musta had a Looneyville moment! ...and I’m sure you’ll need ever burp of that gas ! .... will you be able to pipe that in to your ski lodge ?
[Re: DrCharles]
#2731631
01/10/20 01:08 AM
01/10/20 01:08 AM
Posts: 7,499 Minnesota
Hemi_Joel
Minnesota
I pre-buy 1000 gallons per year in mid summer when prices are low. I don't have to take delivery of all 1000 gallons at once, they come out on a regular schedule and keep it full. I usually don't use 1000 gallons, so I get credit for what I don't use Wow... that must be a thousand bucks (or two) just to heat your shop! I used to live in Presque Isle, Maine and in Feb. the heating oil bill was more than the mortgage (small older house). And worth every penny Doctor C.! This is Minnesota, but I definitely I don't do cold.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
