Heater Blower Motor-Melted Fuse Box Location #2730059
01/04/20 05:46 PM
01/04/20 05:46 PM
Paducah, KY USA Earth
jcruse64 Offline OP
jcruse64  Offline OP
73 truck with pretty much the same problem as in this thread:
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/showflat/Number/2588526/Searchpage/2/Main/214707/Words/%2Bblower+%2Bmotor/Search/true/blower-fuse-overheating.html#Post2588526
In doing some wiring repair on this truck under the dash, I ended up running new wire coming out of the steering column ignition harness; the black power wire had been way hot and brittled up both connectors. I ran the ignition harness blue wire (Accy) to a terminal stud up under my dash on the firewall. I then ran the blue wire from other side of this connector, which runs under the dash to a welded splice and then on to the fuse box for Accessories, to this new terminal stud.
My problem; at the fuse box location for fuse/power to the blower switch, I had already replaced the toasty end fuse holder/clip with one out of another harness that was in a little better shape, and it's held up, but with the plastic melted away, I'm a little worried about it vibrating loose and heating up worse. Any reason I could not safely run this power wire for the blower switch to my new terminal stud for Accy power, putting a 20A inline fuse in between the stud and the switch?
Thanks,
Joe
Re: Heater Blower Motor-Melted Fuse Box Location [Re: jcruse64] #2730276
01/05/20 02:05 PM
01/05/20 02:05 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I did a very similar thing on my 1972 W200 for the same reason.
Re: Heater Blower Motor-Melted Fuse Box Location [Re: 6PakBee] #2730300
01/05/20 02:47 PM
01/05/20 02:47 PM
jcruse64 Offline OP
jcruse64  Offline OP
Thank you, 6PB! I will be putting this on relay(s) in the near future, but that still won't address the fact that the power wire from the fuse box to the blower switch itself is still sketchy, even if relays are taking the load off that switch.
Regards,
Joe
