Stock 5.2 roller lifters
#2729207
01/02/20 12:08 AM
01/02/20 12:08 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
So does the side oil hole go up or down in the bore?
I have almost 3 sets of these and I want to use a good set of 16 in my 410 Stroker 5.9. But the book on how to build Big Cube LA engines says to install them with the paint stripe up to keep from trapping air inside. None of my 40 that I have on hand have any paint.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
Re: Stock 5.2 roller lifters
[Re: Dave_J]
#2729439
01/02/20 07:11 PM
01/02/20 07:11 PM
Dave_J
Auburn WA
Guess not an easy question.
[Re: Dave_J]
#2729455
01/02/20 08:12 PM
01/02/20 08:12 PM
Posts: 4,684 On the parachute mount
n20mstr
Im pretty sure the holes face up or in towards the lifter valley
IF no one else answers , ask Brian at IMM . He is on here and has built some magnums
....BAD A$$ STREET CAR.....
[Re: Dave_J]
#2729459
01/02/20 08:25 PM
01/02/20 08:25 PM
Posts: 82 New York
64 Sportfury
New York
For what it's worth, I am currently assembling a 318 LA roller engine using Sealed Power Magnum replacement roller lifters (HT2269). All of the research I have read on Mopar forums state the hole faces up in the bore. "I have found LA roller lifter bleed hole (looking from front of car) are orientated front to back, I believe Magnums are side to side. The LA rollers can bleed off sometimes after sitting for a while causing lifter ticks until warm up. Lifters can be interchanged, *keep Magnum lifter bleed hole On the top side of engine*, keep LA roller bleed hole on the higher side of the engine (measure engine with spirt level when on level ground" https://www.forabodiesonly.com/mopar/threads/sealed-power-lifts.407676/#post-1972082129 go to post #12 Ernesto
[Re: 64 Sportfury]
#2729522
01/02/20 11:49 PM
01/02/20 11:49 PM
Dave_J
Auburn WA
For what it's worth, I am currently assembling a 318 LA roller engine using Sealed Power Magnum replacement roller lifters (HT2269). All of the research I have read on Mopar forums state the hole faces up in the bore. "I have found LA roller lifter bleed hole (looking from front of car) are orientated front to back, I believe Magnums are side to side. The LA rollers can bleed off sometimes after sitting for a while causing lifter ticks until warm up. Lifters can be interchanged, *keep Magnum lifter bleed hole On the top side of engine*, keep LA roller bleed hole on the higher side of the engine (measure engine with spirt level when on level ground" https://www.forabodiesonly.com/mopar/threads/sealed-power-lifts.407676/#post-1972082129 go to post #12 Ernesto From FABO: Oh wait.....are these factory roller lifters? If so, they install only ONE WAY. With the oil hole facing the INSIDE of the lifter valley. Face them the other way and they bleed down. OK Thanks.
