2863215 VS 2863216 Fan Blades? #2728290
12/30/19 12:50 PM
12/30/19 12:50 PM
N.W. INDIANA
moparjohn Offline OP
N.W. INDIANA
I have a Mopar fan blade that has been re-painted and would like to know the differences between a 2863215 blade and a 2863216 blade?
Also when did Mopar stop stamping into the metal blades and start paint stamping the part number?
Thanks! MJ
Re: 2863215 VS 2863216 Fan Blades? [Re: moparjohn] #2728299
12/30/19 01:30 PM
12/30/19 01:30 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The paint stamp numbers & metal stamp numbers were in use at the same time. Possibly just different suppliers.
215 fans have an 18" diameter & the 216 is 18.5" diameter.
Re: 2863215 VS 2863216 Fan Blades? [Re: Alaskan_TA] #2728307
12/30/19 02:00 PM
12/30/19 02:00 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
plus different notch in the blades on each...215 in front, 216 in rear.
Pictures of ink stamp and metal stamp on a 215
Re: 2863215 VS 2863216 Fan Blades? [Re: mccannix] #2728324
12/30/19 03:08 PM
12/30/19 03:08 PM
N.W. INDIANA
N.W. INDIANA
Thanks for the replies and information!
I have attached a couple of pictures of my fan.
The cut outs on the blades make me think it's a 215
and it's also 18" in diameter!
Any ideas on what fan clutch it has?
MJ
Re: 2863215 VS 2863216 Fan Blades? [Re: moparjohn] #2728341
12/30/19 04:17 PM
12/30/19 04:17 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
I don’t know this to be true and I don’t want to muddy the water but someone told me years ago they also have a different pitch to the blades? Maybe someone with both can have a look and see?
Re: 2863215 VS 2863216 Fan Blades? [Re: Suregrip391] #2728404
12/30/19 08:37 PM
12/30/19 08:37 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
Not 100% sure but I think the 215 has a 2.25" pitch and the 216 has 2.5"
Re: 2863215 VS 2863216 Fan Blades? [Re: moparjohn] #2728609
12/31/19 04:44 PM
12/31/19 04:44 PM
Las Vegas, NV
chargerbr549 Offline
Las Vegas, NV
Looks like a 2806070 fan clutch
Re: 2863215 VS 2863216 Fan Blades? [Re: chargerbr549] #2729062
01/01/20 04:40 PM
01/01/20 04:40 PM
N.W. INDIANA
N.W. INDIANA
chargerbr549,
By the height of the stem 1 1/4" and hub diameter of 7 1/4" I believe the clutch is a 2806070 also.
Thanks! MJ
Re: 2863215 VS 2863216 Fan Blades? [Re: moparjohn] #2729094
01/01/20 06:04 PM
01/01/20 06:04 PM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
Take a q tip and rub off any grease on the seal where the hub meets the clutch...red is 070, blue is a 112...the 112 is a little taller than a 070 when measured...sits a little deeper into the shroud.
Re: 2863215 VS 2863216 Fan Blades? [Re: shakerjoe] #2729097
01/01/20 06:13 PM
01/01/20 06:13 PM
N.W. INDIANA
N.W. INDIANA
shakerjoe,
I did the q-tip test and there is a red seal again confirming it's a 070.
Thanks! MJ
Re: 2863215 VS 2863216 Fan Blades? [Re: shakerjoe] #2729130
01/01/20 08:17 PM
01/01/20 08:17 PM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
nice tid bit that I never knew before. Thanks for sharing.
inherited a 69 roadrunner from my grand pop.
