2863215 VS 2863216 Fan Blades?
#2728290
12/30/19 12:50 PM
12/30/19 12:50 PM
Posts: 1,453 N.W. INDIANA
moparjohn
N.W. INDIANA
I have a Mopar fan blade that has been re-painted and would like to know the differences between a 2863215 blade and a 2863216 blade? Also when did Mopar stop stamping into the metal blades and start paint stamping the part number? Thanks! MJ
Re: 2863215 VS 2863216 Fan Blades?
[Re: mccannix]
#2728324
12/30/19 03:08 PM
12/30/19 03:08 PM
moparjohn
N.W. INDIANA
Thanks for the replies and information! I have attached a couple of pictures of my fan. The cut outs on the blades make me think it's a 215 and it's also 18" in diameter! Any ideas on what fan clutch it has? MJ
[Re: shakerjoe]
#2729130
01/01/20 08:17 PM
01/01/20 08:17 PM
Posts: 356 Greenwood Lake, NY
fuelishnsilly
Greenwood Lake, NY
Take a q tip and rub off any grease on the seal where the hub meets the clutch...red is 070, blue is a 112...the 112 is a little taller than a 070 when measured...sits a little deeper into the shroud. nice tid bit that I never knew before. Thanks for sharing.
inherited a 69 roadrunner from my grand pop.
