Old hyd floor jack rebuild ??s
#2728066
12/29/19 05:45 PM
12/29/19 05:45 PM
Posts: 8,914 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
I have this older Blackhawk floorjack I bought back in the 80's Its a well made professional unit but developed problems so I got a kit and rebuilt it. Now it has a leak issue. The problem is there are no seals or o-rings around the cylinder - either top or bottom. When I assembled it I used some Loctite form-a-gasket but it leaked. When I took it apart this time I found the crap hadn't set up OR the hydraulic fluid reacted and dissolved it. Either way, its leaking. So I'm looking for a better product to use. I don't think silicone is going to cut it AND I hate using that crap 'cause it crumbles when you take things apart and the bits get everywhere. I'm thinking I need a sealant that will set up hard.
Re: Old hyd floor jack rebuild ??s
[Re: Stanton]
#2728069
12/29/19 06:03 PM
12/29/19 06:03 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Here's the cylinder breakdown As you can see - no seals between the base (42) cylinder (31) and retaining nut (32)
[Re: kidmopar]
#2728083
12/29/19 06:34 PM
12/29/19 06:34 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Thanks for that invaluable input. This thing has lasted over 35 years. Let's see where those HF pieces of crap are in 35 years !!
By the way, you can buy complete rebuild kits for these for under $15, I think that speaks volumes.
[Re: Stanton]
#2728109
12/29/19 07:45 PM
12/29/19 07:45 PM
Posts: 1,413 Central Pa
moparjim79
Central Pa
Here's the cylinder breakdown As you can see - no seals between the base (42) cylinder (31) and retaining nut (32) Post the number description list. Having a hard time believing theres no wiper seal anywhere near the ram....
[Re: moparjim79]
#2728116
12/29/19 07:54 PM
12/29/19 07:54 PM
Stanton
Don't question me!
Don't question me!
Ontario, Canada
Of course there's a seal for the ram! That isn't the issue. The issue is: there are no seals on the reservoir cylinder. None in the parts drawing, none on the parts list and none during the initial teardown.
Here's PDF of the jack: parts breakdown and parts list
[Re: floyd]
#2728186
12/30/19 12:51 AM
12/30/19 12:51 AM
Posts: 8,411 Highland, MI.
Sunroofcuda
Highland, MI.
I love the old made in USA floor jacks & think they are worth rebuilding/restoring every time. I have a NAPA made in USA jack from the mid-80's. Newer imported jacks - I don't trust them. The steel China uses in anything is questionable at best.
