New Carrillo Rod Material #2727243
12/27/19 12:26 AM
12/27/19 12:26 AM
A collage of whims
topside Offline OP
topside  Offline OP
A collage of whims
https://www.dragzine.com/features/p...debuts-two-new-connecting-rod-materials/
Interesting, at least from the standpoint of same or better strength with less size, as in stroker applications, and less weight...
Re: New Carrillo Rod Material [Re: topside] #2727254
12/27/19 01:11 AM
12/27/19 01:11 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Nice! Stronger, lighter con rods. I'll check them out for my next build.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: New Carrillo Rod Material [Re: Hemi_Joel] #2727258
12/27/19 01:46 AM
12/27/19 01:46 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Don't get me wrong I am sure they are fantastic. Just don't forget the Alloy Master Card when you call them.....
Re: New Carrillo Rod Material [Re: sasquatch] #2727260
12/27/19 02:12 AM
12/27/19 02:12 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
laugh2 laugh2
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: New Carrillo Rod Material [Re: sasquatch] #2727323
12/27/19 11:05 AM
12/27/19 11:05 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
laugh laugh laugh
Re: New Carrillo Rod Material [Re: sasquatch] #2727343
12/27/19 11:54 AM
12/27/19 11:54 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
That's for the 1350 rods, the 1850 is the AMEX Centurion Card
Re: New Carrillo Rod Material [Re: topside] #2727418
12/27/19 03:42 PM
12/27/19 03:42 PM
New York
polyspheric Offline
polyspheric  Offline
New York
No engineers here?
Boffin Emeritus
Re: New Carrillo Rod Material [Re: Hemi_Joel] #2727424
12/27/19 04:04 PM
12/27/19 04:04 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
The Deusenberg?
Re: New Carrillo Rod Material [Re: topside] #2727435
12/27/19 04:49 PM
12/27/19 04:49 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Have you seen these? Good to 3000hp@15000rpm. I think these carbon fiber rods are for 4 cylinder apps, but they are available for what I understand for LS as well.
https___api.thedrive.com_wp-content_uploads_2019_11_Carbon-Composite-Connecting-Rods-Extreme-Tuners-Hero-Nov-2019.jpg2jz-Carbon-Fiber-Connecting-Rod-Keiron-Berndt-Speedhunters-SEMA-2018-10-30-2018-6701-1200x800.jpg
Re: New Carrillo Rod Material [Re: polyspheric] #2727541
12/27/19 10:18 PM
12/27/19 10:18 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Originally Posted by polyspheric
No engineers here?
pre edit, re big end increase in stiffness salesman prior comment
Ok, I spill the beans, steel alloys vary little in thier stiffness, modulus of elasticity and all
Re: New Carrillo Rod Material [Re: jcc] #2727586
12/28/19 01:39 AM
12/28/19 01:39 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
No engineers here?
Yep, all steels are around 30Msi modulus. Aluminum is around 10Msi, Titanium around 15Msi. Beryllium is the best, stiffer than steel, lighter than aluminum, yield strength isn't all that great though.
I asked Warren Johnson back in the late 1980s about carbon fiber rods. He said they were too stiff and beat the bearings out. It looks like that design allows some cushion in the design. I thought Polyspheric was an engineer from his posts.
Floyd Lippencott IV
Re: New Carrillo Rod Material [Re: mr_340] #2727657
12/28/19 12:39 PM
12/28/19 12:39 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Interesting profiling on the 1850 rod big end - I wonder what effect that has on oil leaving the bearing if any at all. I really wish they would show some real data from the lab to back up the big claims - its pretty easy to test rods on a universal to failure.
The little slip on the product presenter (PC term for sales person these days at trade shows) - is somewhat explained in the whole quote “The rods will be a little stiffer on the big end, because of the strength of the material. The housings will stay a little bit rounder and will maintain shape better, longer.” Most people do not understand the term stiffness when discussing metallurgy.
As far as carbon fiber rods - I was told just the opposite - they tend to be a little too elastic with oil temperature change - thus making it more difficult to keep the oil clearance needed to keep the bearing from becoming unhappy with the crank. However in 20+ years since that - there has been significant improvement in the arena of resins and how they construct the fibers. A couple of the NASCAR teams experimented with CF rods just for qualifying when they were allowed to do that and most went the titanium route.
Re: New Carrillo Rod Material [Re: DoubleD] #2727670
12/28/19 01:01 PM
12/28/19 01:01 PM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Yeah, Titanium. Half the weight of steel, and what, twenty times the cost?
Maybe even more.
Re: New Carrillo Rod Material [Re: mopar dave] #2727692
12/28/19 01:37 PM
12/28/19 01:37 PM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
I've been accused of being stuck in a different time....I think I'll stay there. dino
Re: New Carrillo Rod Material [Re: DoubleD] #2727697
12/28/19 01:42 PM
12/28/19 01:42 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I thought one of the downsides to a carbon fiber rod is that it doesn't have much safety zone for failure. It doesn't stretch or bend; it shatters.
Re: New Carrillo Rod Material [Re: BradH] #2727745
12/28/19 03:35 PM
12/28/19 03:35 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Yes, that would be correct, but you can design around that, the biggest issue IMO, and already mentioned here, is it poor heat suitability as a con rod solution.
They have adapted it already to F1 transaxle cases, so its likely only a matter of time.
Re: New Carrillo Rod Material [Re: jcc] #2727753
12/28/19 03:54 PM
12/28/19 03:54 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
In the 80's, TF builders were experimenting with plastic push rods. There were strong and stiff that they pierced the rocker arms.
Re: New Carrillo Rod Material [Re: BradH] #2727795
12/28/19 06:16 PM
12/28/19 06:16 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I would bet when they do break they don't do the damage to rest of the package as any kind of other rod would.
Re: New Carrillo Rod Material [Re: mopar dave] #2727836
12/28/19 08:41 PM
12/28/19 08:41 PM
USA
hudsonhornet7x Online content
hudsonhornet7x  Online Content
USA
I was thinking the same thing. Might be a block saver.
Re: New Carrillo Rod Material [Re: A/MP] #2727839
12/28/19 08:52 PM
12/28/19 08:52 PM
New York
polyspheric Offline
polyspheric  Offline
New York
LOL
Boffin Emeritus
