Re: New Carrillo Rod Material
[Re: topside]
#2727254
12/27/19 01:11 AM
12/27/19 01:11 AM
Posts: 7,491 Minnesota
Hemi_Joel
Minnesota
Nice! Stronger, lighter con rods. I'll check them out for my next build.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: sasquatch]
#2727260
12/27/19 02:12 AM
12/27/19 02:12 AM
Hemi_Joel
Minnesota
Don't get me wrong I am sure they are fantastic. Just don't forget the Alloy Master Card when you call them.....
[Re: sasquatch]
#2727343
12/27/19 11:54 AM
12/27/19 11:54 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Don't get me wrong I am sure they are fantastic. Just don't forget the Alloy Master Card when you call them..... That's for the 1350 rods, the 1850 is the AMEX Centurion Card
[Re: Hemi_Joel]
#2727424
12/27/19 04:04 PM
12/27/19 04:04 PM
Posts: 3,589 Topeka Kansas
ksj
Topeka Kansas
Nice! Stronger, lighter con rods. I'll check them out for my next build. The Deusenberg?
[Re: topside]
#2727435
12/27/19 04:49 PM
12/27/19 04:49 PM
Posts: 8,042 Mt Morris Michigan
mopar dave
Mt Morris Michigan
Have you seen these? Good to 3000hp@15000rpm. I think these carbon fiber rods are for 4 cylinder apps, but they are available for what I understand for LS as well.
[Re: polyspheric]
#2727541
12/27/19 10:18 PM
12/27/19 10:18 PM
jcc
Bitopia
pre edit, re big end increase in stiffness salesman prior comment Ok, I spill the beans, steel alloys vary little in thier stiffness, modulus of elasticity and all
[Re: jcc]
#2727586
12/28/19 01:39 AM
12/28/19 01:39 AM
Posts: 3,505 DFW
mr_340
DFW
pre edit, re big end increase in stiffness salesman prior comment Ok, I spill the beans, steel alloys vary little in thier stiffness, modulus of elasticity and all Yep, all steels are around 30Msi modulus. Aluminum is around 10Msi, Titanium around 15Msi. Beryllium is the best, stiffer than steel, lighter than aluminum, yield strength isn't all that great though. I asked Warren Johnson back in the late 1980s about carbon fiber rods. He said they were too stiff and beat the bearings out. It looks like that design allows some cushion in the design. I thought Polyspheric was an engineer from his posts.
Floyd Lippencott IV
[Re: DoubleD]
#2727670
12/28/19 01:01 PM
12/28/19 01:01 PM
Posts: 1,837 South Bend
John Brown
South Bend
Yeah, Titanium. Half the weight of steel, and what, twenty times the cost?
Maybe even more.
[Re: BradH]
#2727745
12/28/19 03:35 PM
12/28/19 03:35 PM
jcc
Bitopia
Yes, that would be correct, but you can design around that, the biggest issue IMO, and already mentioned here, is it poor heat suitability as a con rod solution.
They have adapted it already to F1 transaxle cases, so its likely only a matter of time.
[Re: mopar dave]
#2727836
12/28/19 08:41 PM
12/28/19 08:41 PM
Posts: 1,542 USA
hudsonhornet7x
USA
I would bet when they do break they don't do the damage to rest of the package as any kind of other rod would. I was thinking the same thing. Might be a block saver.
