Re: New Carrillo Rod Material [Re: hudsonhornet7x] #2727842
12/28/19 09:00 PM
12/28/19 09:00 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Originally Posted by hudsonhornet7x
Originally Posted by mopar dave
I would bet when they do break they don't do the damage to rest of the package as any kind of other rod would.
I was thinking the same thing. Might be a block saver.
Where would the piston/pin end up, both NA and blown in a CF total rod failure?
Re: New Carrillo Rod Material [Re: jcc] #2727850
12/28/19 09:29 PM
12/28/19 09:29 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Exactly. I have seen first hand what damage a steel rod can do when it breaks. Destroyed my block, destroyed my oil pump, destroyed my roller cam, destroyed 2 pistons and another rod and oil pan. Think a carbon fiber rod would do that?
Re: New Carrillo Rod Material [Re: mopar dave] #2727907
12/29/19 08:03 AM
12/29/19 08:03 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Ti rods have long been known to beat bearings up too. The real change in usage of materials has come from EFI. Every last serious racing engine ever built that used a carburetor is a detonation machine. They all det on the shift, and no prostock team ever solved it. EFI has, or can eliminate detonation. That is the only reason we see these crazy HP numbers with engine longevity.
TI rods used to beat the bearing out after a few passes on a big bad NA motor. Now they run for a season at 3 times the power with EFI .
A real world example is WJ would have to do top rings and rod bearings after 30 pulls on the dyno. Now 100+ is no big deal with EFI
Re: New Carrillo Rod Material [Re: topside] #2727989
12/29/19 01:03 PM
12/29/19 01:03 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Until they provide some real technical info it all rings hollow. They probably are using a different material in these rods but in what way? They say the cheaper ones are 22% stronger and the others 44% but the 4340 they reference is a heat-treat steel that you can make as strong as you want up to a point (where they would be quite brittle).
A couple of years ago I was researching rods and this company had been left behind. This is just a way to get some ink and new interest in their products. There's probably not a lot of substance behind it.
“The rods will be a little stiffer on the big end, because of the strength of the material. The housings will stay a little bit rounder and will maintain shape better, longer.” -Richard Batchelor, Connecting Rod Sales Manager
That's the kind of BS you get from a marketing/sales person, they tend to be full of it.
Re: New Carrillo Rod Material [Re: topside] #2728043
12/29/19 04:21 PM
12/29/19 04:21 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
whistling
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: New Carrillo Rod Material [Re: WHITEDART] #2728062
12/29/19 05:37 PM
12/29/19 05:37 PM
Thigh-Gap Junction
@#$%&*! Offline
@#$%&*!  Offline
Thigh-Gap Junction
Is that the new 22% stronger or the new 44% stronger. Remember, more is better even without a basis for measurement.
Re: New Carrillo Rod Material [Re: @#$%&*!] #2728181
12/30/19 12:36 AM
12/30/19 12:36 AM
DFW
mr_340 Offline
mr_340  Offline
DFW
Anyone have an idea what the new alloys are? I was thinking the 1350 alloy might be Maraging 350. The 1850 sounds like an Inconel or related number to me. Just a guess on my part from no real information other than the yield stress numbers.
https://www.magellanmetals.com/maraging-c350-vascomax-350
Floyd Lippencott IV
Re: New Carrillo Rod Material [Re: WHITEDART] #2728388
12/30/19 08:01 PM
12/30/19 08:01 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Originally Posted by WHITEDART
whistling
A PAPER PLATE?!?!?!?!
The Carrilllo rod goes on the fine china. Fer shame.
