VVT delete timing set #2727162
12/26/19 06:36 PM
12/26/19 06:36 PM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Anyone come out with a timing set to do away with the cam phaser on VVT motors yet? I was hoping something would come out after SEMA or PRI but have not heard or seen anything. I'm really surprised no one has done this yet. And I'm not talking about the kit that uses a non-vvt cam in a vvt engine.
Re: VVT delete timing set [Re: fbs63] #2727175
12/26/19 07:19 PM
12/26/19 07:19 PM
Australia
L4staero Offline
L4staero  Offline
Australia
I think Stef made something on his new engine
Re: VVT delete timing set [Re: L4staero] #2727185
12/26/19 07:46 PM
12/26/19 07:46 PM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Yes, he made a belt drive. Requires an external oil pump.
Re: VVT delete timing set [Re: fbs63] #2727302
12/27/19 09:58 AM
12/27/19 09:58 AM
Indy
496 A-body Offline
496 A-body  Offline
Indy
Re: VVT delete timing set [Re: fbs63] #2728389
12/30/19 08:11 PM
12/30/19 08:11 PM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
This Spring Ric (ric3xrt) is coming out with his set up some time in March, He's got 25k miles on one the of prototypes and 12k on another He's also going to offer a service on rebuilding and setting the phasre up so it goes from 5* advance to 24* retard instead of 0* to 29* .
Here's a video he did on the stock phaser
https://www.youtube.com/watch?v=ug7MCLccUHk&t=9s
Here's the BGE on 5.7 block video
https://www.youtube.com/watch?v=ZqRGUXbp4ls
....just think a 2.225 Intake and 1 .65 exhause valve in a 3.917 bore.....Got to love A Hemi.
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: VVT delete timing set [Re: Ray408G3Hemi] #2728490
12/31/19 10:24 AM
12/31/19 10:24 AM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Im building a Procharger motor and torn between a 5.7 non-vvt or a BGE block. I have both blocks. I have a billet 3.795 crank so its 370 in the 5.7 or 401 in the BGE. I really want the extra cubes of the BGE but don't know about the timing set up. Im a machinist so I am considering building a gear drive. Steff and Jesel both make belt drives so that's something to consider also. Is Ric3xrt set up a modified piece or will it be manufactured by someone? Thanks for the info!
Re: VVT delete timing set [Re: fbs63] #2728541
12/31/19 01:45 PM
12/31/19 01:45 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Go with the BGE, this system is not that complicated (I am having some trouble with one right now but have done a bunch of trouble free ones), you get more cubes, less valve shrouding and a much sturdier block.
Re: VVT delete timing set [Re: fbs63] #2731693
01/10/20 11:08 AM
01/10/20 11:08 AM
Springtown Pa
Springtown Pa
Modified piece uses a Progear 4000 set for a 6.1 ,it's not hard to make, Dave's right about the VVT once it's locked it's not going any where, I've seen Ric lock them with a roll pin,
1996 Viper GTS
Re: VVT delete timing set [Re: Ray408G3Hemi] #2731698
01/10/20 11:27 AM
01/10/20 11:27 AM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Thanks for the reply's. I'm a machinist so I can make whatever I need. Seriously thinking about a gear drive that will fit under the stock cover. Mounting holes already exist for the mounting plate so I don't think it would be difficult.
Re: VVT delete timing set [Re: fbs63] #2743388
02/15/20 11:20 PM
02/15/20 11:20 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Well we want pics of how you do it, if and when you do...Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: VVT delete timing set [Re: astjp2] #2743462
02/16/20 09:45 AM
02/16/20 09:45 AM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Just need to put a crank in the block and figure out the crank gear offset and I will have the gear drive complete. I will post pics when I'm done.
Re: VVT delete timing set [Re: fbs63] #2743782
02/16/20 10:42 PM
02/16/20 10:42 PM
Parts Unknown
WildHorse Offline
WildHorse  Offline
Parts Unknown
So this is strictly for drag racing? Or are u gonna run locked out VVT on the street as well? Not a daily I'm assuming?
2017 Mustang GT | Grabber Blue | MT82 | 3.31 | FIREHAWK INDY 500 | | JLT CAI | JLT Oil Separator | Heartthrob H-Pipe | K&N air filter | 93 octane tune by DIABLOMATT.
All motor 11.27 @ 125 mph 1.69 60ft on street tires
Re: VVT delete timing set [Re: WildHorse] #2743846
02/17/20 07:51 AM
02/17/20 07:51 AM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Yes, fast street and strip. BGE 428 with an F3D106 Procharger. No vvt.
Re: VVT delete timing set [Re: fbs63] #2744491
02/19/20 08:16 AM
02/19/20 08:16 AM
ghinmi Offline
ghinmi  Offline
I've been running vvt locked for 29,900 miles now. Using the Comp phaser lock kit. I degreed the cam by broaching new keyways in the lower sprocket.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
Re: VVT delete timing set [Re: ghinmi] #2748110
03/01/20 07:31 PM
03/01/20 07:31 PM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
Here's a couple pics of the gear drive. Have to finish hone the crank gear and cut recess for the oil pump. You get the idea though.
Re: VVT delete timing set [Re: fbs63] #2748322
03/02/20 02:46 PM
03/02/20 02:46 PM
NE
corkscrew426 Offline
NE
You plan on coming to market with that? I am looking for something I can spin to 8-8,500 rpm reliably.
Re: VVT delete timing set [Re: corkscrew426] #2748340
03/02/20 03:52 PM
03/02/20 03:52 PM
NW Indiana
fbs63 Offline OP
fbs63  Offline OP
NW Indiana
I want to see how it works and the longevity of it first. Appreciate you asking though.
