Re: VVT delete timing set
[Re: fbs63]
#2727302
12/27/19 09:58 AM
12/27/19 09:58 AM
Posts: 369 Indy
496 A-body
Indy
[Re: fbs63]
#2728389
12/30/19 08:11 PM
12/30/19 08:11 PM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
Anyone come out with a timing set to do away with the cam phaser on VVT motors yet? I was hoping something would come out after SEMA or PRI but have not heard or seen anything. I'm really surprised no one has done this yet. And I'm not talking about the kit that uses a non-vvt cam in a vvt engine. This Spring Ric (ric3xrt) is coming out with his set up some time in March, He's got 25k miles on one the of prototypes and 12k on another He's also going to offer a service on rebuilding and setting the phasre up so it goes from 5* advance to 24* retard instead of 0* to 29* . Here's a video he did on the stock phaser https://www.youtube.com/watch?v=ug7MCLccUHk&t=9sHere's the BGE on 5.7 block video https://www.youtube.com/watch?v=ZqRGUXbp4ls....just think a 2.225 Intake and 1 .65 exhause valve in a 3.917 bore.....Got to love A Hemi.
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
[Re: fbs63]
#2728541
12/31/19 01:45 PM
12/31/19 01:45 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
Go with the BGE, this system is not that complicated (I am having some trouble with one right now but have done a bunch of trouble free ones), you get more cubes, less valve shrouding and a much sturdier block.
[Re: fbs63]
#2731693
01/10/20 11:08 AM
01/10/20 11:08 AM
Ray408G3Hemi
Springtown Pa
Im building a Procharger motor and torn between a 5.7 non-vvt or a BGE block. I have both blocks. I have a billet 3.795 crank so its 370 in the 5.7 or 401 in the BGE. I really want the extra cubes of the BGE but don't know about the timing set up. Im a machinist so I am considering building a gear drive. Steff and Jesel both make belt drives so that's something to consider also. Is Ric3xrt set up a modified piece or will it be manufactured by someone? Thanks for the info! Modified piece uses a Progear 4000 set for a 6.1 ,it's not hard to make, Dave's right about the VVT once it's locked it's not going any where, I've seen Ric lock them with a roll pin,
[Re: fbs63]
#2743388
02/15/20 11:20 PM
02/15/20 11:20 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
Thanks for the reply's. I'm a machinist so I can make whatever I need. Seriously thinking about a gear drive that will fit under the stock cover. Mounting holes already exist for the mounting plate so I don't think it would be difficult. Well we want pics of how you do it, if and when you do...Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2743462
02/16/20 09:45 AM
02/16/20 09:45 AM
Posts: 1,837 NW Indiana
fbs63
NW Indiana
Thanks for the reply's. I'm a machinist so I can make whatever I need. Seriously thinking about a gear drive that will fit under the stock cover. Mounting holes already exist for the mounting plate so I don't think it would be difficult. Well we want pics of how you do it, if and when you do...Tim Just need to put a crank in the block and figure out the crank gear offset and I will have the gear drive complete. I will post pics when I'm done.
[Re: fbs63]
#2743782
02/16/20 10:42 PM
02/16/20 10:42 PM
Posts: 11 Parts Unknown
WildHorse
Parts Unknown
So this is strictly for drag racing? Or are u gonna run locked out VVT on the street as well? Not a daily I'm assuming?
2017 Mustang GT | Grabber Blue | MT82 | 3.31 | FIREHAWK INDY 500 | | JLT CAI | JLT Oil Separator | Heartthrob H-Pipe | K&N air filter | 93 octane tune by DIABLOMATT. All motor 11.27 @ 125 mph 1.69 60ft on street tires
[Re: fbs63]
#2744491
02/19/20 08:16 AM
02/19/20 08:16 AM
Posts: 112 Michigan
ghinmi
I've been running vvt locked for 29,900 miles now. Using the Comp phaser lock kit. I degreed the cam by broaching new keyways in the lower sprocket.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street. 9.97 @ 140 slicks, 10.74 in autox trim
