Re: Torque spec for vistor head with studs
[Re: mopar dave]
#2727208
12/26/19 08:47 PM
12/26/19 08:47 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
My white instruction sheet calls for 80Ft. Lbs. with the new ARP lube, I used 75 Ft. lb. on the current motor I'm building with 440-1 heads and Cometic .066 thick MLS head gaskets with the ARP head studs. The pistons rock over to max height on this motor are right at .030 above the deck so I'm pushing the piston to head clearances with .036 measured on the highest piston edge, the rest have slightly more piston to head clearances
