Chrome window trim cleaning #2726190
12/22/19 05:35 PM
12/22/19 05:35 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I got alot of basecoat and clear on a few pieces of windshield chrome trim.
How can I get it clean and look good again?
Re: Chrome window trim cleaning [Re: Sammy] #2726195
12/22/19 06:10 PM
12/22/19 06:10 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Most of the stuff that people think is chrome is actually stainless steel. Try paint stripper or solvent/reducer.
Re: Chrome window trim cleaning [Re: Neil] #2726196
12/22/19 06:13 PM
12/22/19 06:13 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I tried that.
Theres just way too much paint on the trim.
Re: Chrome window trim cleaning [Re: Sammy] #2726226
12/22/19 07:50 PM
12/22/19 07:50 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
How does this front windshield trim come off?
I got the rear off, it was held on with screws.
Re: Chrome window trim cleaning [Re: Sammy] #2726234
12/22/19 08:07 PM
12/22/19 08:07 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Silly question whistling What's the car ????
Sillier question, how did this happen ?? shruggy
Re: Chrome window trim cleaning [Re: Sammy] #2726578
12/24/19 12:00 PM
12/24/19 12:00 PM
pa.
dan9 Offline
dan9  Offline
pa.
What car has the trim held on by screws? To answer your question the safest way is use the same reducer that you used in the paint.
Re: Chrome window trim cleaning [Re: dan9] #2726764
12/25/19 10:46 AM
12/25/19 10:46 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I'm talking about the front windshield trim.
There are no screws holding it on. How does it come off?
Going to try the reducer today without taking off the trim but I think it's not going to work. Basecoat clearcoat has been on for months now.
Re: Chrome window trim cleaning [Re: Sammy] #2726768
12/25/19 11:02 AM
12/25/19 11:02 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Take it off, use paint stripper, clean, polish, reinstall. Any chemical means you will use is likely to damage the paint you want to keep.
As for how to take it off, that depends on what vehicle it is. The body section of the FSM usually covers that.
Re: Chrome window trim cleaning [Re: Sammy] #2726842
12/25/19 04:15 PM
12/25/19 04:15 PM
You need a special tool to release the inside fasteners on most Mopar front windshield trim used on 1968 A bodies, not sure about B and C bodies
Re: Chrome window trim cleaning [Re: Cab_Burge] #2726883
12/25/19 07:16 PM
12/25/19 07:16 PM
Central Florida
larrymopar360 Online content
Stud Muffin
larrymopar360  Online Content
Stud Muffin
Central Florida
I bought trim remover kit from Harbor Freight cheap. I knew it wasn't the kind of think I needed often or in high quality. It has several pieces and all the ones you may need.
Facts are stubborn things.
Re: Chrome window trim cleaning [Re: Sammy] #2726948
12/26/19 12:19 AM
12/26/19 12:19 AM
Colorado
dssaa Offline
dssaa  Offline
Colorado
Nail polish remover....the acetone type. I use it all the time...and no, not on my nails....Less harsh then paint stripper. And cheap.
Re: Chrome window trim cleaning [Re: dssaa] #2726966
12/26/19 02:44 AM
12/26/19 02:44 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Wedge a piece of thin plastic sheet between trim & body. Shields the painted side. Go at mldg with 0000 steelwool, or 000 to start. If paint comes off, you've also "polished" the mldg. w/o removing. Any solvent are likely to come in contact with the paint with dire consequences.
