Summit racing’s CR calculator #2725836
12/21/19 12:16 PM
12/21/19 12:16 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I’ve been comparing Summits CR calculator to several others including Wallace racing and Diamond pistons website. They are almost .75 in cr higher than other sites. Anyone notice that? Maybe CYA?
Re: Summit racing’s CR calculator [Re: fastmark] #2725849
12/21/19 12:50 PM
12/21/19 12:50 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
It's simple math. Not sure how they manage to come up with different answers. Ratio of volume at BDC vs. volume at TDC. shruggy
Re: Summit racing’s CR calculator [Re: fastmark] #2726053
12/22/19 11:42 AM
12/22/19 11:42 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Do they factor in deck height, dome volume, valve relief notches, gasket width?
Boffin Emeritus
Re: Summit racing’s CR calculator [Re: fastmark] #2726059
12/22/19 11:57 AM
12/22/19 11:57 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The compression calculator I use was about $8 at Staples.
Re: Summit racing’s CR calculator [Re: fast68plymouth] #2726131
12/22/19 02:45 PM
12/22/19 02:45 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
If the Summit calculator disagrees with the figure that Wallace, Diamond and everyone else comes up with, I would just discount the Summit number.
Re: Summit racing’s CR calculator [Re: fastmark] #2726185
12/22/19 05:20 PM
12/22/19 05:20 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Make sure you have you valve relief/dome/dish pluses and minuses correct.
Re: Summit racing’s CR calculator [Re: BSB67] #2726208
12/22/19 06:51 PM
12/22/19 06:51 PM
Washington
skrews Offline
skrews  Offline
Washington
Seems accurate to me.
Re: Summit racing’s CR calculator [Re: skrews] #2726213
12/22/19 07:19 PM
12/22/19 07:19 PM
So. Burlington, Vt.
So. Burlington, Vt.
Fundamentally, it produces the correct result for what inputs there are...... but there aren’t quite enough.
No input for gasket bore(so I have to assume it’s using the same as the cylinder bore), and it doesn’t take into account the area above the rings.
Modeling a 446 with dome pistons down the hole .010 and a 4.41 bore gasket that’s .045 thick, my staples calculator and the Summit calculator differed by .15:1 ....... the summit one being higher, since there was no input for the bigger gasket bore or the area above the rings.
If I remove the volume for the area above the rings and make the gasket bore the same as the cylinder bore, the result is within .02:1(which is likely from a difference in how far out the decimal point is taken for each entry).
Edit- it does appear there is a slight error with what’s its using for a conversion from CI to CC though.
4.35 x 3.75 x 8 cyls is 445.85ci..... which it has as correct.
But the conversion to CC is 16.387...... which is 7306.14cc.
It’s showing the displacement cc as 7309.02(16.393 conversion).
Re: Summit racing’s CR calculator [Re: fastmark] #2726219
12/22/19 07:27 PM
12/22/19 07:27 PM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
I use Diamond piston calculator. Its the best most accurate one I have found yet.
Re: Summit racing’s CR calculator [Re: mopar dave] #2726252
12/22/19 09:05 PM
12/22/19 09:05 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Summit does not use the head gasket diameter nor the area about the first ring. The diamond one does use more measurements. I had everything right and used it several times. Not sure why it’s so much higher.
Re: Summit racing’s CR calculator [Re: fastmark] #2726255
12/22/19 09:09 PM
12/22/19 09:09 PM
So. Burlington, Vt.
So. Burlington, Vt.
Well, what are all your specs?
Btw...... my staples calculator agrees with the Diamond calculator. smoke
Re: Summit racing’s CR calculator [Re: fastmark] #2726660
12/24/19 04:22 PM
12/24/19 04:22 PM
Springtown Pa
Ray408G3Hemi Offline
Springtown Pa
with only a few things to factor I think they have it set up for higher results so it's more of "Max" # , and not a exact # that way the novice builder errors on the high side...let be honest if you build engines for a living your not using that calculator......I use it to bench race and get a vague idea.
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: Summit racing’s CR calculator [Re: Ray408G3Hemi] #2726689
12/24/19 07:51 PM
12/24/19 07:51 PM
I use United Machine calculator and I have used the Wallace calculator on the same motor and numbers used on both and saw about .3 ratio differences between those two confused shruggy
Re: Summit racing’s CR calculator [Re: fast68plymouth] #2726690
12/24/19 07:55 PM
12/24/19 07:55 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Mine is the button at the upper-right corner of my keyboard. Seems okay so far, is configurable to scientific and does unit conversions.
