Re: Summit racing’s CR calculator
[Re: fastmark]
#2725849
12/21/19 12:50 PM
12/21/19 12:50 PM
Posts: 11,578 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
It's simple math. Not sure how they manage to come up with different answers. Ratio of volume at BDC vs. volume at TDC.
[Re: fastmark]
#2726053
12/22/19 11:42 AM
12/22/19 11:42 AM
Posts: 4,206 New York
polyspheric
New York
Do they factor in deck height, dome volume, valve relief notches, gasket width?
Boffin Emeritus
[Re: fastmark]
#2726059
12/22/19 11:57 AM
12/22/19 11:57 AM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The compression calculator I use was about $8 at Staples.
[Re: fast68plymouth]
#2726131
12/22/19 02:45 PM
12/22/19 02:45 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If the Summit calculator disagrees with the figure that Wallace, Diamond and everyone else comes up with, I would just discount the Summit number.
[Re: skrews]
#2726213
12/22/19 07:19 PM
12/22/19 07:19 PM
fast68plymouth
So. Burlington, Vt.
Fundamentally, it produces the correct result for what inputs there are...... but there aren’t quite enough.
No input for gasket bore(so I have to assume it’s using the same as the cylinder bore), and it doesn’t take into account the area above the rings.
Modeling a 446 with dome pistons down the hole .010 and a 4.41 bore gasket that’s .045 thick, my staples calculator and the Summit calculator differed by .15:1 ....... the summit one being higher, since there was no input for the bigger gasket bore or the area above the rings.
If I remove the volume for the area above the rings and make the gasket bore the same as the cylinder bore, the result is within .02:1(which is likely from a difference in how far out the decimal point is taken for each entry).
Edit- it does appear there is a slight error with what’s its using for a conversion from CI to CC though. 4.35 x 3.75 x 8 cyls is 445.85ci..... which it has as correct. But the conversion to CC is 16.387...... which is 7306.14cc. It’s showing the displacement cc as 7309.02(16.393 conversion).
[Re: fastmark]
#2726255
12/22/19 09:09 PM
12/22/19 09:09 PM
fast68plymouth
So. Burlington, Vt.
Well, what are all your specs? Btw...... my staples calculator agrees with the Diamond calculator.
[Re: fastmark]
#2726660
12/24/19 04:22 PM
12/24/19 04:22 PM
Posts: 194 Springtown Pa
Ray408G3Hemi
Springtown Pa
I’ve been comparing Summits CR calculator to several others including Wallace racing and Diamond pistons website. They are almost .75 in cr higher than other sites. Anyone notice that? Maybe CYA? with only a few things to factor I think they have it set up for higher results so it's more of "Max" # , and not a exact # that way the novice builder errors on the high side...let be honest if you build engines for a living your not using that calculator......I use it to bench race and get a vague idea.
1963 Thunderbolt 496FE 10.80 (still a work in progress) 1968 Mustang slow a$$ 428 FE 1971 Boss 351 Mustang 11.20@115mph 1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA 1996 Viper GTS 2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor 2009 Ram 9.65@144MPH 463CI G3 NA 2010 Challenger 9.91 @ 139MPH 408CI G3ci NA 2019 F150 (local dealer's Lightning package) ..11.90s
#2726690
12/24/19 07:55 PM
12/24/19 07:55 PM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
The compression calculator I use was about $8 at Staples. Mine is the button at the upper-right corner of my keyboard. Seems okay so far, is configurable to scientific and does unit conversions.
