Need to locate Hemi rocker arms 426 #2725790
12/21/19 09:44 AM
12/21/19 09:44 AM
ill
dennismopar73 Offline OP
ill
Anyone have idea where I can locate a set of complete rocker arm assembly for 426 Hemi
Does the 426use different set of shafts than a 440?
Re: Need to locate Hemi rocker arms 426 [Re: dennismopar73] #2725798
12/21/19 10:10 AM
12/21/19 10:10 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Very different. We will need some more info on the engine and it's application to make a recommendation on rocker assemblies. There are a bunch of different ones and their quality, application, and price varies widely. But none are cheap, not even the cheap ones.
Master, again and still
Re: Need to locate Hemi rocker arms 426 [Re: DaveRS23] #2725839
12/21/19 12:25 PM
12/21/19 12:25 PM
iagree whiney
I use to race a 426 hemi in NHRA stock back in 1974 to 1976. I went through around 4 sets of stock 426 rocker arms looking for the best set, I checked all of them on the same legal camshaft on one side of my motor with light checking springs , I saw between .430 to .530 lift on all of those rockers. Legal was .484 on the intakes and .466 on the exhaust, I think shruggy
My message is those stock rocker are not very good on the accuracy of the ratio on them down
Re: Need to locate Hemi rocker arms 426 [Re: Cab_Burge] #2725935
12/21/19 06:59 PM
12/21/19 06:59 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
My stock hemi rockers were within .010-.015 of each on all.
Re: Need to locate Hemi rocker arms 426 [Re: Hot 340] #2726089
12/22/19 01:01 PM
12/22/19 01:01 PM
Northeast
Racer68 Offline
Racer68  Offline
Northeast
I just bought a TD rocker set for my Indy heads. Don't know much about them. My engine builder suggested them. The motor will be on the dyno in the next couple of weeks. I'm not saying I'm going to make anymore power with these but didn't want to use Indy's rockers.
Re: Need to locate Hemi rocker arms 426 [Re: dennismopar73] #2726120
12/22/19 02:14 PM
12/22/19 02:14 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Buy some good aftermarket rockers. The money you will spend buying used OEM and reworking them to a good set you can buy a set of Stave V or similar. twocents
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Need to locate Hemi rocker arms 426 [Re: Hot 340] #2726123
12/22/19 02:19 PM
12/22/19 02:19 PM
I wonder if they had been rebuilt and blueprinted before you got them work
I wished that I had a set like those up
Re: Need to locate Hemi rocker arms 426 [Re: Cab_Burge] #2726202
12/22/19 06:37 PM
12/22/19 06:37 PM
Byron, NY
Byron, NY
Once I had a set of matched Wide pad stock rockers and they came from an A/Gas MPH record holder who had retired (Bill Drake). A set of OEM rockers is gonna run you $1600-$2400, then they need to be re-bushed and ground (matched) and their still 45-55 yr old parts. For the same and maybe a little less money you can have a set of Stage V brand new rockers, and good luck finding Wide pad rockers. With any luck you may find some used Kluf rockers but you are going to pay dearly for those too.
At the price these thing are going for I wish I had all the sets I've sold back...to sell again!
'60 Willys CJ5
Re: Need to locate Hemi rocker arms 426 [Re: W.I.N. Racing] #2726231
12/22/19 08:00 PM
12/22/19 08:00 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Depending on what you’re building, the ones from Mancini for $1900 might be all you need.
They’re what Muscle Motors used on the 572 giveaway hemi.
Re: Need to locate Hemi rocker arms 426 [Re: fast68plymouth] #2726932
12/25/19 10:32 PM
12/25/19 10:32 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
H Got mine from Todd @ http://www.mopartsracing.com/
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Need to locate Hemi rocker arms 426 [Re: hemi-itis] #2726950
12/26/19 12:27 AM
12/26/19 12:27 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Stage V from Bob Massolini for reference.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Need to locate Hemi rocker arms 426 [Re: Hemi Allstate] #2727120
12/26/19 04:56 PM
12/26/19 04:56 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I tried to get my factory rockers blueprinted by t&d, I was getting .100 difference between all 8 of both intake and exhaust. I wound up with StageV and they were within .005. I also installed dechelles top fuel shaft because that is what he gave me a deal on. Worth buying good rockers the first time around.
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Need to locate Hemi rocker arms 426 [Re: astjp2] #2727209
12/26/19 08:50 PM
12/26/19 08:50 PM
I have used RAS twice to bush and blueprint ductile iron BB wedge rocker arms, both time took longer and where more expensive than promised, no more for me down twocents
Re: Need to locate Hemi rocker arms 426 [Re: DaveRS23] #2727287
12/27/19 09:15 AM
12/27/19 09:15 AM
ill
ill
It’s just a stock build, nothing wild ,
Re: Need to locate Hemi rocker arms 426 [Re: dennismopar73] #2727324
12/27/19 11:09 AM
12/27/19 11:09 AM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
I have an extra set of clean used stock rockers, if you're still looking.
Once you have those, then get shafts+shaft stands and you will be well on your way.
Rich H.
Esse Quam Videri
