Re: Need to locate Hemi rocker arms 426
[Re: dennismopar73]
#2725798
12/21/19 10:10 AM
12/21/19 10:10 AM
Posts: 11,996 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Very different. We will need some more info on the engine and it's application to make a recommendation on rocker assemblies. There are a bunch of different ones and their quality, application, and price varies widely. But none are cheap, not even the cheap ones.
Master, again and still
[Re: DaveRS23]
#2725839
12/21/19 12:25 PM
12/21/19 12:25 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
Very different. We will need some more info on the engine and it's application to make a recommendation on rocker assemblies. There are a bunch of different ones and their quality, application, and price varies widely. But none are cheap, not even the cheap ones. I use to race a 426 hemi in NHRA stock back in 1974 to 1976. I went through around 4 sets of stock 426 rocker arms looking for the best set, I checked all of them on the same legal camshaft on one side of my motor with light checking springs , I saw between .430 to .530 lift on all of those rockers. Legal was .484 on the intakes and .466 on the exhaust, I think My message is those stock rocker are not very good on the accuracy of the ratio on them
[Re: dennismopar73]
#2726120
12/22/19 02:14 PM
12/22/19 02:14 PM
Posts: 2,102 Byron, NY
W.I.N. Racing
Byron, NY
Buy some good aftermarket rockers. The money you will spend buying used OEM and reworking them to a good set you can buy a set of Stave V or similar.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Hot 340]
#2726123
12/22/19 02:19 PM
12/22/19 02:19 PM
Cab_Burge
My stock hemi rockers were within .010-.015 of each on all. I wonder if they had been rebuilt and blueprinted before you got them I wished that I had a set like those
[Re: Cab_Burge]
#2726202
12/22/19 06:37 PM
12/22/19 06:37 PM
W.I.N. Racing
Byron, NY
Once I had a set of matched Wide pad stock rockers and they came from an A/Gas MPH record holder who had retired (Bill Drake). A set of OEM rockers is gonna run you $1600-$2400, then they need to be re-bushed and ground (matched) and their still 45-55 yr old parts. For the same and maybe a little less money you can have a set of Stage V brand new rockers, and good luck finding Wide pad rockers. With any luck you may find some used Kluf rockers but you are going to pay dearly for those too. At the price these thing are going for I wish I had all the sets I've sold back...to sell again!
[Re: W.I.N. Racing]
#2726231
12/22/19 08:00 PM
12/22/19 08:00 PM
Posts: 14,491 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Depending on what you’re building, the ones from Mancini for $1900 might be all you need.
They’re what Muscle Motors used on the 572 giveaway hemi.
[Re: Hemi Allstate]
#2727120
12/26/19 04:56 PM
12/26/19 04:56 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I tried to get my factory rockers blueprinted by t&d, I was getting .100 difference between all 8 of both intake and exhaust. I wound up with StageV and they were within .005. I also installed dechelles top fuel shaft because that is what he gave me a deal on. Worth buying good rockers the first time around.
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: dennismopar73]
#2727324
12/27/19 11:09 AM
12/27/19 11:09 AM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
Thanks It’s just a stock build, nothing wild , I have an extra set of clean used stock rockers, if you're still looking. Once you have those, then get shafts+shaft stands and you will be well on your way.
Rich H.
Esse Quam Videri
