Re: What aftermarket Cruise Control do you use?
[Re: TC@HP2]
#2725598
12/20/19 11:41 AM
12/20/19 11:41 AM
Posts: 6,326 nowhere
Sniper
nowhere
Rostra does that still. http://www.rostra.com/universal-aftermarket-cruise-control-by-rostra.phpI never liked the flying magnets speed sensor nor using the tach signal. But you could adapt a STANDARD MOTOR PRODUCTS SC108 to provide both an electrical signal for the CC and keep your mechanical speedometer or use the Rostra adapter if it'll work for you.
[Re: McCandlessboy]
#2725675
12/20/19 04:49 PM
12/20/19 04:49 PM
Posts: 235 Central Mississippi
mopar97
Central Mississippi
Will be adding a cruise to a few cars over the winter. Just curious which ones people are using and why. We used to put the ones out of a 5th avenue on, but finally ran out. I'd like to avoid the long stalk off the wheel. I installed one bought at J C Whitney years ago. The controller attached to the turn signal stalk. It was a little trial and error but it worked ok for what it was. This was late 80,early 90.
Mopar born, Mopar breed, when I die, call me Mopar dead!
[Re: mopar97]
#2725737
12/20/19 09:54 PM
12/20/19 09:54 PM
Posts: 3,380 KY USA
mopargem
KY USA
Will be adding a cruise to a few cars over the winter. Just curious which ones people are using and why. We used to put the ones out of a 5th avenue on, but finally ran out. I'd like to avoid the long stalk off the wheel. I installed one bought at J C Whitney years ago. The controller attached to the turn signal stalk. It was a little trial and error but it worked ok for what it was. This was late 80,early 90. You just took the words out of my mouth! I put a JC Whitney unit on my 81 elCamino around 1988 for our big fishing trip to Boundary Waters Minn and it worked great!
[Re: dOc …]
#2726040
12/22/19 10:38 AM
12/22/19 10:38 AM
Posts: 211 Halifax, VA.
moparjack44
Halifax, VA.
Not wanting to hijack this thread, but any recommendations for a 2 4's set up?
K.I.S.S.
