What aftermarket Cruise Control do you use? #2725494
12/19/19 10:32 PM
12/19/19 10:32 PM
McCandlessboy Offline OP
Will be adding cruise to a few cars over the winter. Just curious which ones people are using and why. We used to put the ones out of a 5th avenue on, but finally ran out. I'd like to avoid the long stalk off the wheel.
Re: What aftermarket Cruise Control do you use? [Re: McCandlessboy] #2725498
12/19/19 10:49 PM
12/19/19 10:49 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
For what type of car?
I added it to my 1970 Fury III sedan but I located all the correct vintage parts first.
Re: What aftermarket Cruise Control do you use? [Re: McCandlessboy] #2725578
12/20/19 10:40 AM
12/20/19 10:40 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
There used to be companies like Fridgette and ARA that made aftermarket cruise systems for non-OEM cars that installed very easily, had their own control systems. Many moons ago I worked at a company installing these. The option of an OEM style stalk controller or a dash mounted box were available. Not sure if they still exist or if they have been replaced by more solid state type of units.
I bet some one at Car Toys could answer that question.
Re: What aftermarket Cruise Control do you use? [Re: TC@HP2] #2725598
12/20/19 11:41 AM
12/20/19 11:41 AM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Rostra does that still.
http://www.rostra.com/universal-aftermarket-cruise-control-by-rostra.php
I never liked the flying magnets speed sensor nor using the tach signal. But you could adapt a STANDARD MOTOR PRODUCTS SC108 to provide both an electrical signal for the CC and keep your mechanical speedometer or use the Rostra adapter if it'll work for you.
Re: What aftermarket Cruise Control do you use? [Re: McCandlessboy] #2725675
12/20/19 04:49 PM
12/20/19 04:49 PM
Central Mississippi
mopar97 Offline
mopar97  Offline
Central Mississippi
Originally Posted by McCandlessboy
Will be adding a cruise to a few cars over the winter. Just curious which ones people are using and why. We used to put the ones out of a 5th avenue on, but finally ran out. I'd like to avoid the long stalk off the wheel.
I installed one bought at J C Whitney years ago. The controller attached to the turn signal stalk. It was a little trial and error but it worked ok for what it was. This was late 80,early 90.
Mopar born, Mopar breed, when I die, call me Mopar dead!
Re: What aftermarket Cruise Control do you use? [Re: mopar97] #2725737
12/20/19 09:54 PM
12/20/19 09:54 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
You just took the words out of my mouth! I put a JC Whitney unit on my 81 elCamino around 1988 for our big fishing trip to Boundary Waters Minn and it worked great!
Re: What aftermarket Cruise Control do you use? [Re: mopargem] #2725740
12/20/19 10:01 PM
12/20/19 10:01 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
The Rostra units work pretty well. You have to buy the switch separately these days, but there are several switch units to choose from. Gene
Re: What aftermarket Cruise Control do you use? [Re: mopargem] #2726033
12/22/19 09:42 AM
12/22/19 09:42 AM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
Ole JCW used to have a very wide range of selection .... not any more though.
Before I moved up to northern Michigan I bought 4 sets on a close out .... they are gone.
Re: What aftermarket Cruise Control do you use? [Re: dOrk !] #2726040
12/22/19 10:38 AM
12/22/19 10:38 AM
Halifax, VA.
moparjack44 Offline
moparjack44  Offline
Halifax, VA.
Not wanting to hijack this thread, but any recommendations for a 2 4's set up?
K.I.S.S.
Re: What aftermarket Cruise Control do you use? [Re: Sniper] #2726111
12/22/19 01:57 PM
12/22/19 01:57 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Thos look similar to what I was installing wit Fridgette and ARA. Electronic module with a cable actuated throttle kit and an inline speed sensor running off the speedo cable. Beat the hell out of the flying magnet kits of the time.
