P7 Heads on a ritter block #2725487
12/19/19 10:12 PM
12/19/19 10:12 PM
Springtown Pa
Ray408G3Hemi Offline OP
Springtown Pa
I'm not a "Mopar Guy" so I'm asking this out of pure curiosity , but can you bolt a set of the P7 heads on to the New Ritter Block ? I Bought a 65 Dart last week , been debating on going BBM or Sbm,
1963 Thunderbolt 496FE 10.80 (still a work in progress)
1968 Mustang slow a$$ 428 FE
1971 Boss 351 Mustang 11.20@115mph
1993 Lightning 10.61 @ 129mph 408Ci A3 headed NA
1996 Viper GTS
2001 Lightning 8.99 @ 155MPH 5.4 Mod Motor
2009 Ram 9.65@144MPH 463CI G3 NA
2010 Challenger 9.91 @ 139MPH 408CI G3ci NA
2019 F150 (local dealer's Lightning package) ..11.90s
Re: P7 Heads on a ritter block [Re: Ray408G3Hemi] #2725511
12/20/19 12:03 AM
12/20/19 12:03 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
There is a version of the Ritter that is machined for the P7. They are not interchangeable with any other head. I don't believe it is (was?) an easy build but has been done. And the tall deck LA style block can be built bigger than the R5. Being in PA you are fairly close to guys who did it. A complete R5P7 is also an option that would likely be easier and cheaper than the Ritter deal.
Your budget will determine which options are available and sensible.
Re: P7 Heads on a ritter block [Re: Ray408G3Hemi] #2725540
12/20/19 07:59 AM
12/20/19 07:59 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
The P7 head will not fit a standard small block without extensive modifications. As far as I know, the ritter block for p7 heads never was available to the general population. I have a complete P7 top end and cam. I also have an A8 block that I want to mate them to.
Bore space is the same.
Head bolt holes need to be moved.
Cam tunnel needs to be removed and replaced. The P7 lifter bore requires location in the area that currently has cam bearings. The standard block has 5 cam bearings where the p7 requires 7 cam bearings.
Call ritter and see if they have the xr block for P7s available. If they do, it would be an awesome combo.
Also would likely need to fabricate an intake and water manifold.
Re: P7 Heads on a ritter block [Re: TRENDZ] #2725551
12/20/19 08:59 AM
12/20/19 08:59 AM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
Last time I was at Ritter's place he was trying hard to sell me his "new" (v2.0) block for P7 heads. Dude must 100 pair of assembled P7s on the shelf from Arrington/Penske/Chapman/etc.
Call Kent, he has want you need on the shelf/shelves.
Re: P7 Heads on a ritter block [Re: usp4u] #2725557
12/20/19 09:15 AM
12/20/19 09:15 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Its a shame that that info isn’t out there. I was asking about that block for years before assuming it would never happen.
Re: P7 Heads on a ritter block [Re: usp4u] #2725559
12/20/19 09:20 AM
12/20/19 09:20 AM
Springtown Pa
Springtown Pa
Can I get a hold of them thru Hughes , or should I go Direct ?
1996 Viper GTS
Re: P7 Heads on a ritter block [Re: CMcAllister] #2725567
12/20/19 09:45 AM
12/20/19 09:45 AM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
The guys with the green Dart?
Re: P7 Heads on a ritter block [Re: Ray408G3Hemi] #2725569
12/20/19 09:52 AM
12/20/19 09:52 AM
W. Pa
U
usp4u Offline
usp4u  Offline
U
W. Pa
I would just call him.
Re: P7 Heads on a ritter block [Re: usp4u] #2725573
12/20/19 10:15 AM
12/20/19 10:15 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
From what i understand there is ANOTHER option for a block from EEI (Ernie Elliot). So, 3 different blocks available: original r5, Ritters version of the r5 which has a tall deck and is a modular casting that CAN BE machined for either the conventional LA or the P7 heads, and again the EEI which can be purchased in two versions e.g.-open or closed deck surface.
Re: P7 Heads on a ritter block [Re: Ray408G3Hemi] #2725639
12/20/19 01:45 PM
12/20/19 01:45 PM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
Ray if you are thinking about doing a hotdog smallblock I would start with a phone call to Brett Miller.
"Just a Bracket car dressed up like a streetcar"
Re: P7 Heads on a ritter block [Re: Just-a-dart] #2725648
12/20/19 02:35 PM
12/20/19 02:35 PM
East Brunswick New Jersey
N
NoFrills Offline
NoFrills  Offline
N
I was talking to Brent Miller about the ritter p7 deal. If my memory is right he put one togeather that is in a dirt car. From what i understand that block uses the p7 cam and belt drive i think water pump also. I believe the eei block uses a r5 crank set up which kind of suck because it will still need a custom billet. I am planing on boring my r5 block to a 4 300 and change will make it in the 370s i need to buy pistons anyway.
Re: P7 Heads on a ritter block [Re: NoFrills] #2725725
12/20/19 08:41 PM
12/20/19 08:41 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
The only high end small block heads I ever liked were the P5 Hemi heads.....
Re: P7 Heads on a ritter block [Re: Dragula] #2726198
12/22/19 06:26 PM
12/22/19 06:26 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
The Ritter XR2 block takes all the LA stuff, the nose of the camshaft needs to be machined to like a LA camshaft as well. If you're a perfectionist, you could go down the road of a custom cam core. The ritter blocks were designed around the P7 heads, the wedge stuff was made to work around it.
Alan Jones
Re: P7 Heads on a ritter block [Re: LA360] #2726205
12/22/19 06:45 PM
12/22/19 06:45 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Is the XR2 iron or aluminum? Are the available now? What is the price range? Been waiting on this for 10+ years.
Re: P7 Heads on a ritter block [Re: TRENDZ] #2726225
12/22/19 07:41 PM
12/22/19 07:41 PM
LA360 Offline
LA360  Offline
These blocks have been available for as long at the Ritter blocks have, so they will be priced similarly to the XR1 wedge blocks. I have a couple of iron blocks, I believe that aluminium was available as well. Kenny Badorf has an aluminium XR2/P7 deal with a Procharger in his Dart from memory
Alan Jones
