SB Trans Cooler Line Question 727 vs. 904
#2724513
12/16/19 03:10 PM
12/16/19 03:10 PM
Posts: 1,565 Macomb, MI
vinnyd76
Macomb, MI
Question for the Moparts experts... are the small block trans cooler lines the same between 727 and 904?
Re: SB Trans Cooler Line Question 727 vs. 904
[Re: 5thAve]
#2724638
12/16/19 09:13 PM
12/16/19 09:13 PM
vinnyd76
Macomb, MI
They're not the same but they're close enough to make them work. Based on some assembly instructions (for what their worth) appear to be different bend wise coming out of the trans.
[Re: vinnyd76]
#2724697
12/17/19 01:20 AM
12/17/19 01:20 AM
Posts: 20,204 Park Forest, IL
slantzilla
Park Forest, IL
IIRC, when I changed my Challenger from a 904 to a 727 I used the same lines but had to bend the angles different. The fittings in the trans cases aren't exactly in the same places. (This was only 40 years ago or so)
[Re: slantzilla]
#2724931
12/17/19 09:11 PM
12/17/19 09:11 PM
Posts: 4,156 Canada -- Posts: 4034 -Registe...
5thAve
IIRC, when I changed my Challenger from a 904 to a 727 I used the same lines but had to bend the angles different. The fittings in the trans cases aren't exactly in the same places. (This was only 40 years ago or so) That's what I hit. The fittings are off enough that you have to fight with the line to get it connected but close enough that it'll still work when you're on your side under the car wanting to get it back together.
[Re: moparwizard]
#2724974
12/17/19 10:47 PM
12/17/19 10:47 PM
vinnyd76
Macomb, MI
1970 SB 727 A-BODY COOLER LINES Thank you very much for posting the pics of the cooler lines. Attached is what they sold me.
[Re: vinnyd76]
#2725115
12/18/19 12:56 PM
12/18/19 12:56 PM
Posts: 25,941 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The distance between the cooler fittings on the case is about the same (8.5" ±) but the 904 fitting is closer to the pan rail so the line has less arch to it.
