SB Trans Cooler Line Question 727 vs. 904 #2724513
12/16/19 03:10 PM
12/16/19 03:10 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Question for the Moparts experts... are the small block trans cooler lines the same between 727 and 904?
Re: SB Trans Cooler Line Question 727 vs. 904 [Re: vinnyd76] #2724522
12/16/19 03:27 PM
12/16/19 03:27 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Nope
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: SB Trans Cooler Line Question 727 vs. 904 [Re: moparmarks] #2724627
12/16/19 08:44 PM
12/16/19 08:44 PM
5thAve Offline
5thAve  Offline
They're not the same but they're close enough to make them work.
Re: SB Trans Cooler Line Question 727 vs. 904 [Re: 5thAve] #2724638
12/16/19 09:13 PM
12/16/19 09:13 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Based on some assembly instructions (for what their worth) appear to be different bend wise coming out of the trans.
Re: SB Trans Cooler Line Question 727 vs. 904 [Re: vinnyd76] #2724692
12/17/19 01:05 AM
12/17/19 01:05 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Anyone have photos of their original 727 cooler lines that they can share?
Re: SB Trans Cooler Line Question 727 vs. 904 [Re: vinnyd76] #2724697
12/17/19 01:20 AM
12/17/19 01:20 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
IIRC, when I changed my Challenger from a 904 to a 727 I used the same lines but had to bend the angles different. The fittings in the trans cases aren't exactly in the same places. (This was only 40 years ago or so)
Re: SB Trans Cooler Line Question 727 vs. 904 [Re: slantzilla] #2724884
12/17/19 05:48 PM
12/17/19 05:48 PM
FL
moparwizard Offline
moparwizard  Offline
FL
1970 SB 727 A-BODY COOLER LINES
Re: SB Trans Cooler Line Question 727 vs. 904 [Re: slantzilla] #2724931
12/17/19 09:11 PM
12/17/19 09:11 PM
5thAve Offline
5thAve  Offline
That's what I hit. The fittings are off enough that you have to fight with the line to get it connected but close enough that it'll still work when you're on your side under the car wanting to get it back together.
Re: SB Trans Cooler Line Question 727 vs. 904 [Re: moparwizard] #2724974
12/17/19 10:47 PM
12/17/19 10:47 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Thank you very much for posting the pics of the cooler lines. Attached is what they sold me.
Re: SB Trans Cooler Line Question 727 vs. 904 [Re: vinnyd76] #2725115
12/18/19 12:56 PM
12/18/19 12:56 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The distance between the cooler fittings on the case is about the same (8.5" ±) but the 904 fitting is closer to the pan rail so the line has less arch to it.
