rear main seal retainer offset? #2723640
12/13/19 05:23 AM
12/13/19 05:23 AM
Graz, Austria
DGS Offline OP
DGS  Offline OP
Graz, Austria
Why are all rear main seal retainers offset to one side? I found this on original retainers as well as on aftermarket ones...
Compare the distance of the outer edge to the bolt holes left and right. On the right side there is slightly more material:
clearly visible:
Re: rear main seal retainer offset? [Re: DGS] #2723683
12/13/19 10:57 AM
12/13/19 10:57 AM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Look at every main cap and you'll see they're offset too. So they get installed correctly.
Re: rear main seal retainer offset? [Re: DGS] #2723741
12/13/19 01:58 PM
12/13/19 01:58 PM
Manufacturers specs. and the company that makes them tolerances can vary some work
If the threads in the stock retainer are still good that is the one I would use on a stock block up twocents
Re: rear main seal retainer offset? [Re: Cab_Burge] #2723747
12/13/19 02:11 PM
12/13/19 02:11 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Cab,I don't think there are any threads in the retainer ! no grin
Re: rear main seal retainer offset? [Re: 62maxwgn] #2723753
12/13/19 02:17 PM
12/13/19 02:17 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
He means threads for the oil pan.
Re: rear main seal retainer offset? [Re: 4406bbl] #2723782
12/13/19 04:41 PM
12/13/19 04:41 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
See what happens when you get old !! realcrazy
Re: rear main seal retainer offset? [Re: 62maxwgn] #2724181
12/15/19 01:25 PM
12/15/19 01:25 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I remember Monte Smith used to post that he would enlarge the holes slightly to get the retainer centered on the crank journal to keep them leak free. He also used to clock the ends of the seal at 12 and 6 too but I have yet to try that method shruggy
Gus beer
64 Plymouth Savoy
Dana 60
